Mini-ZRacer.com Forums
Mini-ZRacer.com Forums (http://mini-zracer.com/forums/index.php)
-   Kyosho (http://mini-zracer.com/forums/forumdisplay.php?f=77)
-   -   Does Mr02 LM differential fit MR03 ? (http://mini-zracer.com/forums/showthread.php?t=41521)
Smokey_truck 2019.04.08 05:41 PM
Smokey
EMU 2019.04.08 08:37 PM
Mr02 and mr03 share the same rear pods. The LM differential is specific to the LM pod but can be used on a standard rear pod with 2mm shims on each side of the axle around the mount to compensate for the extra 4mm length of the diff shaft. Spur gears with offset teeth will need to have the teeth closer to the center of the pod.
Smokey_truck 2019.04.08 08:53 PM
Great thank you sir
