Old 2007.10.16, 05:24 PM   #1
mini-z
Administrator
mini-z's Avatar
Exclamation New for 2008: MR02LM and 2.4Ghz Radio System
New Perfex Transmitter, KT-18 ASF
  • The new KT-18 TX unit will allow 40 Mini-Zs to race at the same time.
  • Will automatically search for an open Frequency, NO Xtals needed!
  • Radio response speed increased 33%, compared to the KT-5
  • Only one radio required to control other 2.4ghz equipped Mini-Zs
  • Steering angle and throttle angles can be adjusted
  • Digital trim adjustments
  • Blue LED lights indicate Power, Bind Mode, and Training mode
  • Only 4 AAA Batteries required for TX operation
  • Expansion slot for add on features. (available in future)
80021B TX only
MSRP NYA
Release Date: Jan/Feb
MR02LM Series with 2.4Ghz System ARR
  • Fully factory assembled chassis with high capacity FET
  • NEW 2.4Ghz radio system
  • Pre painted bodies
  • Four sizes of pinion gears
  • Pinion gear tool
  • Spacers for front suspension adjustment
30441KR-B Porsche 962 No.10
MSRP NYA
TECHNICAL DATA
Scale: 1/27.6
Length: 180mm
Width: 78mm
Height: 39mm
Wheelbase: 102mm
Weight: 130g
Gear Ratios: 7.3, 6.3, 5.5, 4.9:1
Tire Diameter: (F)23.5mm (R)27mm
Tire Width: (F)9mm (R)12mm
Transmitter: KT-18 (Sold Separately)
* NEW FEATURES *
  • New motor case and friction dampener as
    standard equipment.
  • Motor now located 5.5mm lower and
    2.5mm toward the center, compared to the MM motor case.
  • Equipped with I.C.S Port
  • Transmitter and receiver response time has increased 33%
  • 2.4Ghz Technology, Antenna
mini-z is offline   Reply With Quote
HTML code is On
2.4GHz replacing AM system svt-racer Mini-ZRacer.com Mini-Z Dojo, Ann Arbor MI 24 2008.04.21 08:58 PM
Perfex KT-18 ASF 2.4Ghz System pchan0 2.4GHz ASF System (Auto Selected Frequency) 204 2008.02.23 03:59 PM
Perfex KT-18 ASF 2.4Ghz System arch2b Transmitters, Receivers and Crystals 0 2007.10.21 09:47 AM
2.4Ghz AFS System Tim Johnson 2.4GHz ASF System (Auto Selected Frequency) 0 2007.10.16 05:45 PM
Perfex KT-18 ASF 2.4Ghz System arch2b Kyosho 0 2007.10.11 12:11 PM
