Old 2012.02.22, 06:52 AM   #1
Fovea3d
Fovea3d's Avatar
Mini-z body Shara
Received the first print of the Shara. The model is perfect and needs no editing.
- Low and ultrawide body! Needs a LM axle and largest wheel offset
- blower with air scoop and rear fake chassis are included but mount is optional for weight saving.
-Tested on a MR03 chassis stock (x-speed). Very stable and "square" behaviour. Rounded front nose will slide on obstacles. No rear overhang at all. Side body clip area very rigid due to the presence of the side air intakes (same effect as the Enzo body). Large side air intakes and rear openings will keep the motor cool.
Specs.
For MR02-03W. Needs a LM axle for correct widdness
wheelbase 98mm
+3F/+4.5R
Weight 17.8gr without snap-on accessories
Link
Pictured with Tagus +4.5 rear and +2 front (I don't have +3 Tagus 5 spokes).
Feel free to post your own realisations here. This thread is also open to requests for improvement of this body.
3d printed bodies and parts
mini6z
European mini-z forum
My mini-z collection
Fovea3d is offline   Reply With Quote
Old 2012.02.22, 06:53 AM   #2
Fovea3d
Fovea3d's Avatar
These are renderings of the car as it should look finished (will replace with pictures or the actual model when painted).
mini6z
Old 2012.02.24, 11:44 AM   #3
leonen
Scuderia Leone Racing
leonen's Avatar
Send a message via MSN to leonen
I want it!!!!
Néstor Leone
Buenos Aires, Argentina.
Http://www CircuitoZur.com.ar/
Http://www.ScuderiaLeoneRacing com.ar/
leonen is offline   Reply With Quote
Old 2012.02.24, 11:57 AM   #4
ShortBus
Independant Driver
ShortBus's Avatar
are these printed bodies durable - how do they compare to the actual autoscale?
Jeff S.
Action-less
ShortBus is offline   Reply With Quote
Old 2012.02.24, 12:07 PM   #5
Fovea3d
Fovea3d's Avatar
Find a clear plastic tupperware box somewhere in your kitchen and twist it in all directions Thats about how it feels. It also reminds me of fishing line (its nylon).
It is also ultralight due to the air emprisonned in the structure, the weight is close to lexan.
About durability, I tried to snatch a mirror on a body, I had to fold and twist it several times before it broke.
I look forward to your tests with these bodies, it might be something revolutionary.
mini6z
Old 2012.02.24, 12:29 PM   #6
Fovea3d
Fovea3d's Avatar
Already did that test but now with a painted body
video
This body has a thickness of 0.75mm. If made thicker like the autoscales (1 to 1.5mm) it would be more rigid and really indestructible.
Heavier also. The Camaro you see here weights 14.7gr bare/19.6gr with the paint.
mini6z
Old 2012.02.24, 01:59 PM   #7
ShortBus
Independant Driver
ShortBus's Avatar
Wow, I am impressed !!
Jeff S.
Action-less
Old 2012.02.24, 02:01 PM   #8
leonen
leonen's Avatar
Ok.. so how can I get you to send me one of this???
How much does it cost?
Néstor Leone
Old 2012.02.24, 02:05 PM   #9
chad508
chad508's Avatar
click the link in his signature. the bodies are made to order
PN Racing
R1Wurks
LET's Go Racing
DG Designs
chad508 is offline   Reply With Quote
Old 2012.03.04, 07:51 PM   #10
Skv012a
Skv012a's Avatar
Send a message via ICQ to Skv012a Send a message via AIM to Skv012a Send a message via MSN to Skv012a Send a message via Yahoo to Skv012a
So, are the side clips integrated into the shell on all of these or do we still have to get sets (from your shapeway or elsewhere)?
New site.
Skv012a is offline   Reply With Quote
Old 2012.03.05, 11:04 AM   #11
Fovea3d
Fovea3d's Avatar
The side clips are integrated into the shell. Those in my shop are for regular bodies (autoscale, white bodies).
mini6z
What Tools Do You Guys Use To Provide Clearance For A Mini Z Body? Starsky5000 Mini-Z Science 7 2011.07.02 03:10 PM
wtb mini z body xmodevodrift Mini-Z Marketplace 2 2009.08.25 08:06 PM
67 Camaro Xmods body on Mini Z HammerZ Custom Bodies 2 2008.02.06 02:15 AM
Mini-z Unpainted Tim Johnson Parts and Hop-ups 13 2006.09.29 02:11 PM
Pugot Body? Raising the Mini Z Chassis and Track Jumping Rally? Mini Z Chicks! <<help MachinaX Parts and Hop-ups 11 2002.05.26 05:25 PM
