Old 2014.10.01, 11:49 AM   #76
dameetz
dameetz's Avatar
Originally Posted by josyskunk View Post
I have a question about the throttle high point, for the standard 1/10 radio using mini z module, the throttle high point is set at 60%( according to KO web site) then what is the throttle high point for KIY EX1 ASF for Mini Z, does the default setting take into account that it is for Mini Z (since it is specially made for mini z only) and using the default setting (which is 100) will use the full range of ESC on the Mini Z board ?
I just bought this radio the latest version 3, I too have the same question as the above quote. From bench test the rpm would peak at 80 hi point travel, is this correct?
dameetz is offline   Reply With Quote
Old 2014.10.01, 11:55 AM   #77
lfisminiz
lfisminiz's Avatar
Seems to be in the 70-80 area.
Old 2014.10.02, 11:09 AM   #78
dameetz
dameetz's Avatar
Thanks for the info
Old 2015.01.26, 05:57 AM   #79
Racer-HH
Racer-HH's Avatar
Just recently bought a new KIY v3 ASF TX.
Now I have the situation, that one car looses binding on training day after approx 10 laps, needs rebinding and works fine just for the rest of the day. This happend two weeks in a row.
It only happens to my VE car on memory slot #6. I still need to check the same car with a different memory slot, but all other cars just work fine on their respective slots.
Any ideas from your side? Return for exchange? Other diy options?
[ my RCs: dNaNo & Mini-Z: MB-010 VE * MC-01 * MF-015 VE Pro * MR-03 VE Pro ]
[ my TX: EX-6 ]
[ my Youtube-Channel: RacersVideos ]
Racer-HH is offline   Reply With Quote
Old 2015.01.26, 10:03 AM   #80
lfisminiz
lfisminiz's Avatar
I havent had any problems with this version or KIY but i know on my Helios i had a similar problem. That model might get corupt on that peticular model #. I had sent it back and they re-flashed it. If its this, try that car on a different model....# 11 or whatever, see if its opk on that one.
Old 2015.01.26, 03:37 PM   #81
dwight
Kiy
I have two KIY radios and one of them won't bind on a few of my channels. I sent it back to KO for the firewall issue I was having and after they fixed that the KIY worked fine on every channel.
dwight is offline   Reply With Quote
Old 2015.01.27, 01:53 PM   #82
KO PROPO Staff
If it's just a particular model memory I would try another to see if you have the same problem. If you don't have a problem on another model memory, then try to reset the problem model memory. I doubt that changing a model memory would solve your problem if all the others are working correctly. It might be something with the car's board.
dwight- never heard of a "firewall" issue, maybe your RF board had a problem and was re-programmed to correct and corruption issues.
KO PROPO Staff is offline   Reply With Quote
Old 2015.07.05, 10:08 AM   #83
Harold996tt
Strangely for mine I need to be well above 70 to get full rpm.
Harold996tt is offline   Reply With Quote
***For Sale: *KO Propo Radio * KO ProPo Mini Z Module *** nugget Mini-Z Marketplace 4 2010.07.29 08:16 AM
ko propo ex-1 mars radio fs bobbyz Mini-Z Marketplace 2 2010.07.19 01:58 AM
FS: Ko Propo EX-I UR radio with upgrades and LIPO davskee Mini-Z Marketplace 3 2009.11.02 04:37 PM
FS: KO Propo EX1-UR with Kyosho radio case reechaard Mini-Z Marketplace 5 2008.11.16 02:11 AM
FS: Ko Propo Mars R radio for Mini-Z - $150 pchan0 Miscellaneous Discussion 0 2003.08.25 04:52 PM
