Old 2015.09.01, 07:52 PM   #1
bobbyz
TDS shock length??
Just need to check on a dimension for a project. Can someone with a PN TDS measure the center to center of the two side shocks when installed. Looks like approx. 22mm or 7/8" from looking at pics, but a physical measurement from someone would be much appreciated.
Thx, Bob
bobbyz is offline   Reply With Quote
Old 2015.10.15, 07:28 AM   #2
LED
What do you mean with center to center?
I can measure the mounting holes and length of the shocks if you like. But the center of the shocks will differ with the setup. The angle of the shocks, etc..
What exactly do you need?
LED is offline   Reply With Quote
Old 2015.10.16, 02:42 PM   #3
bobbyz
Yes it would be the mounting holes. The distance from center of one of the DDS Plate holes to the center of one of the SideSpring Plate holes for just one of the shocks. I guess when the TDS is all together it would actually be from the center of screw to center of screw for just one of the shocks. I'm not sure if this distance varies from the 98mm to 94mm SideSpring Plates. For my purposes I found 24mm works well so far, which is very close to 15/16"
Attached a pic of what I'm looking for.
Thx Much.
Kyosho Mini-Z 2nd Generation Book marc Miscellaneous Discussion 32 2012.12.23 02:47 AM
PN Racing MA-010 AWD Front Double -A- Arm Suspension. eztuner12 Mini-Z AWD MA-010, MA-015 345 2011.10.07 09:05 PM
Silicon Oil Weight(s) for Kyosho MR02 Rear Oil Shock? Felix2010 Mini-Z Racer MR-02 10 2009.04.14 02:23 PM
how to lift and lower your ol, complete instructions. james399 Mini-Z Overland MV-01 32 2008.03.29 02:19 PM
Eagle Mono Oil Shock - Help!! CedMan Parts and Hop-ups 8 2002.08.17 04:27 PM
