Old 2014.06.04, 10:37 PM   #361
yasuji
PN RacingTEAM Driver
yasuji's Avatar
Send a message via AIM to yasuji Send a message via Yahoo to yasuji
Alrighty... here we go... will be testing this tomorrow!
Grant "Yasuji" Matsushima
www.pnracing.com
gm@pnracing.com
yasuji is offline   Reply With Quote
Old 2014.06.17, 01:10 PM   #362
dameetz
dameetz's Avatar
I just bought DAA today for my MR03, its from the latest batch and it comes with '1' etched on the lower arm, does it mean its a +1 lower arm? Also it comes with 4 white spring cup holder which look like the same length altogether (haven't measure it yet).
I m not too sure if the toe bars have changed from the previous batches coz this is my 1st buy on the DAA.
Now can anyone give a good starting set up for the DAA MR03 with +1 lower arm? (if it is the +1 lower arm that i got)
Btw, the .9 allen wrench is still not included....
Thanks
dameetz is offline   Reply With Quote
Old 2014.06.19, 09:28 PM   #363
lfisminiz
lfisminiz's Avatar
Try....
+1 A-arm toe bar.
the pin in upper arm can be put at the up or down or in or out position (notch in pin). start at the 12:00 (up) position.
try version 1 green or purple spring or version 3 blue spring.
Old 2014.08.29, 04:03 AM   #364
dameetz
dameetz's Avatar
Just saw this on kenon site
+2.0 deg toe tie rod
+1.5 deg toe tie rod
Will this give toe in set up when using A-Arm with 1deg wide lower arm?
Old 2014.08.30, 11:11 AM   #365
I'd be curious to find anyone who's used either of these or compared them for length.
I've used the +.5 and +1.0 and found them both of the same length that give me a slight toe out with the +1deg lower arm. If the new wider tie rods could get me a straight alignment I'd be shopping in a second.
Old 2014.08.30, 11:10 PM   #366
Felix2010
I loved that the MR03 Dbl A-Arm came with 3 different steering toe rods... But basically, you only are actually only getting varying degrees toe-out or zero toe... I doubt PN wanted it this way, maybe the machining company miscalculated the tie rods...
I am looking to buy another 03 A-Arm kit and I hope PN will remove one of the 0, +0.5, or +1 tie rods in favor of including a +1.5 or +2 tie rod with the kit so that there will be at least one option for zero actual toe or slight toe-in with the longer lower arms. Just a thought
Thank you PN and Yasuji for always being accessible and working to make customers happy! Rock on PN!
*** TOP SECRET MOTORS ***
[FONT="Book Antiqua"]
Old 2014.08.31, 12:57 AM   #367
yasuji
yasuji's Avatar
Originally Posted by Felix2010 View Post
I loved that the MR03 Dbl A-Arm came with 3 steering toe rods... But basically, you only are actually only getting varying degrees toe-out or zero toe... I doubt PN wanted it this way, maybe the machining company miscalculated the tie rods...
The new 1.5 and 2 degree tow bars do in fact give my car "0" and +toe
The toe bars that come with the kit are designed for the "0" Lower arms
As I have tested them.. It definitely gives the toe in effect that I expect from more +toe
I do not know if PN will be changing to this toe bar in the future but I will discuss this with philip
I am glad that PN was able to push this thru to get out to the public as I do know that we have many exciting new concepts in the works
www.pnracing.com
gm@pnracing.com
Old 2014.08.31, 03:39 AM   #368
Felix2010
Thank you very much Yasuji and Philip N. for always listening to us fellow Mini-Z'ers. And thank you Yasuji for the reply about the new +1.5 and +2 tie rods giving Zero-toe and Toe-in with the longer lower arms.
I appreciate all the hard work you, Philip, and the PN Team put into your product line and look forward to all the Mini-Z PN upgrade concepts to come.
Old 2015.02.03, 06:25 AM   #369
Solo1
Old nut
just installed this front end on a 03s and when i put the tires on the front end is almost touching the ground anyone know what i did wrong or is the s chassie different? Have gone over everything several times and it appears to be on correctly?
Solo1 is offline   Reply With Quote
Old 2015.02.03, 08:41 AM   #370
DMALMAD
DMALMAD's Avatar
You have to adjust the preload and ride height. I suggest you buy pn spring cup and preload spacer kit. It is relatively cheap and allows you to shim the springs as they are generally a little short. Then you use your .09 and 1.5 wrench to adjust ride height and preload from there.
Old 2015.02.03, 11:19 AM   #371
Solo1
Old nut
I googled that and cant find it also checked kenons site and couldn't find it either? Guessing i'll just have to buy some shims as i have the white spring cups
Old 2015.02.03, 11:36 AM   #372
SLMZ / HFAY
You can use the springs cups that came with it. you'll also want to get some of these.
PN Racing Mini-Z MR02/03 Double A Arm Spring Holder Shims Set
# MR2056FS
if you want the additional cups its part # MR2056FL
hope that helps.
Old 2015.02.03, 03:40 PM   #373
Solo1
Old nut
Thanks for the links!
Old 2016.03.07, 08:40 PM   #374
Chicken Little
El Pollo Loco
Chicken Little's Avatar
When are these double a arms for the mr-03 coming back in stock? I need a couple of them for my rides.
Cruizin with R/C Waldwick NJ (201) 445-8080. Mini-Z carpet racing at it's best. The carpet match the drapes.
A bunch of plastic toy RC cars
A bunch of batteries
A bunch of motors
A bunch of tires
A bunch of tools
BB Tuning (stage 2)
Team S.O.L. Racing (now accepting applications)
Requirements: dismal qualifier performance, low main position, 1 POS mini-z.
Chicken Little is offline   Reply With Quote
Old 2016.03.08, 03:34 PM   #375
neoneo1neo
email PN, they should have some
neoneo1neo is offline   Reply With Quote
December 3hr Endurance! Programmers Stafford Mini Z Racers England 26 2009.08.22 07:20 PM
front suspension lowering GME0VR Setups 3 2002.02.01 03:21 AM
Front suspension PorscheGuy964 Parts and Hop-ups 2 2001.12.30 04:49 PM
Suspension and handling Shrubba FAQ 4 2001.11.29 12:54 PM
front suspension budwilson Setups 12 2001.11.11 05:52 PM
