2008.04.23, 09:36 AM
#61
Originally Posted by Cherub1m
Just wondering what chassis did drivers use for the Pan mod. class? I know Cristian used the Inzane car but what about Bill, Scott(Iam guessing he used his pocket knife V8), Bill, Lukas, Chad, Rod, Philip, Mike, Jon, Kalani, Cuyson, Bosley. Did everyone else use Miniz's?
I was running my 94 mm mid mount setup.
1 deg caster PN
2 deg camber PN
0 offset front rims PN
PN-RSF 8 front tires (had to change fronts all weekend for different track conditions)
Yellow PN front springs.
Stock toe bar
PN dampening plate with blue springs top and bottom.
Losi Hydro fluid MED for dampening.
Atomic 2.8mm DPS mount
PN 94 mm pod
Kyosho ball diff with PN 64 pitch gears 57/11
PN RRR06 tires
0 offset rear rims from PN
Team Scream batteries
Am board with 2x2 4562 fets
I think that is about it.
Bill
PN Team Driver
2008 PN World Champion
2008 PN Canadian Champion
2006 PN World Champion
2004 Kyosho Cup National Champion
2003 Kyosho Cup National Champion
2008.04.23, 10:23 AM
#62
Slip Angle Chaser
1 deg caster PN
2 deg camber PN
Stock toe bar
PN 94 mm pod
PN RRR06 tires
Bill
Full set ups are always nice and welcomed. Also, what body did you use Bill?
Thanks.
Philip
Originally Posted by briankstan
Wcrotty was running a MR-02 with the same setup as his stock class car. I didn't get all the details, hopefully he will chime in with the setup.
Originally Posted by DJ Kyosho
Jon (me), Mike, Kalani, Cuyson (NML), Lukas (ambind) and Philip used mini-zs. I don't know about the rest.
Again congrats to you all!!!. Looks like the MRO2 continues to set the standard.
Thanks for the reply guys
Philip Vincent
2008.04.23, 10:52 AM
#63
2008.04.23, 10:55 AM
#64
2008.04.23, 11:05 AM
#65
Thanks for the pictures, I must admit i was looking forward to playing with the Micro-desert but the cars weren't setup so it was just a big mess when they gave us the chance to test them out. From the looks of it, the car isn't worthy of jumping anything. But i must admit it was one fast little sucker.
2008.04.23, 11:14 AM
#66
#67
2008.04.23, 11:15 AM
#68
2008.04.23, 11:17 AM
#69
2008.04.23, 11:55 AM
#70
very nice pics Brian! Thanks for posting it!
2008.04.23, 12:50 PM
#71
NP, I'm uploading the videos I have of the Mains. I'll post the links shortly.
2008.04.23, 01:07 PM
#72
[QUOTE=Cherub1m;300210]Full set ups are always nice and welcomed. Also, what body did you use Bill?
Philip
That setup was my mod setup so it had the pan body. My stock setup
was very similar with the 360gtc body. Here is my stock setup.
1 deg caster PN
3 deg camber PN plastic
PN-RSF 10 front tires (had to change fronts all weekend for different track conditions also)
Purple PN front springs.
Stock toe bar
PN dampening plate with blue springs top. No dampening on the bottom.
PN 94 mm pod
PN RRR06 tires
360gtc body.
Thanks
Bill
PN Team Driver
2008.04.23, 01:50 PM
#73
Slip Angle Chaser
Thanks Bill.
Philip Vincent
2008.04.23, 02:03 PM
#74
Vidoes
2008.04.23, 02:43 PM
#75
you must of have had a big memory card to capture all that footage, nice work!
The video's aren't working for me, anyone else having problems with it?
