Old 2008.05.23, 01:49 PM   #1
benmlee
PN Racing Knuckle Damper Cap
Here is a new small item from PN for the MA010. The caps is made from delrin. Its larger contact area with the knuckle king pin helps to minimize suspension stiction. The shape of it also helps retain damping fluid for the knuckle.
It must be used with PN knuckle, but can be installed on stock chassis without the aluminum upper cover.
Old 2008.05.23, 02:17 PM   #2
Tjay
Tjay's Avatar
if I can only fit this on my plastic kyosho knuckles...
Old 2008.05.27, 01:06 PM   #3
CedMan
Ya, I am surprise someone like Kyosho has not introduce something like this yet, this is one of those simple concept that makes you think ... wait, how come nobody has done this yet ...
Good work PN.
Now only if there is a way to use the plastic knuckles ... of maybe someone will make plastic knuckles that works with this ...
Exclusively MA010 - AM/AD/2.4
CedMan is offline   Reply With Quote
Old 2008.05.28, 11:05 AM   #4
Aurora
Hi, everyone.
Wait a sec, if I understand this correctly, this is much like the PN sleeves on knuckles but now comes with in 'hat' shape?
How is this better in retaining the dampening fluids? I could see it is probably more secure than the 'sleeve', since it will not fell off from top of knuckles.
Old 2008.05.28, 09:26 PM   #5
lfisminiz
lfisminiz's Avatar
Aurora
You take a Pn alum knuckle. Take off the upper delrin sleeve. You have a small alum pin there . You put the knuckle sleeve in upper cover. put some grease inside the knuckle sleeve. when you put everything together, the pin on alum knuckle slips inside of knuckle sleeve (where grease is). Thats it.
Old 2008.05.29, 09:31 AM   #6
Sinister_Y
Sinister_Y's Avatar
Special Note On Using On Older Pn Knuckles
Hi All,
Just a FYI that you have to trim/machine/cut, whatever wording you want to use, the top of the knuckle in order to use the older PN knuckles with these caps. If you don't, there will be minimal suspension travel (and possibly binding). I had this system pre-production and had to do this for all my PN knuckles. This is supposedly not an issue with new PN knuckles.
Old 2008.07.03, 06:41 AM   #7
Tjay
Tjay's Avatar
doen't work for me... also, it gets very messy!
FS: PN Racing AWD silver alloy parts set. pchan0 Mini-Z Marketplace 11 2007.07.16 08:21 PM
Reflex Racing MR-02 World Championship Replica ruf Reflex Racing 25 2006.08.27 09:29 PM
Atlanta Mini Scale Racing Announcement AtlRC Atlanta Mini Scale Racing 43 2006.02.19 07:52 AM
Reflex Racing F1 World Championship Replica ruf Reflex Racing 12 2005.11.18 03:13 PM
main damper and damper plate system PINCIR Mini-Z Racer MR-02 10 2005.09.23 04:06 PM
