Old 2018.12.08, 12:54 AM   #16
HaCo
02-Racer
HaCo's Avatar
It looks like there is a roll damper in the make from Kyosho :
https://m.youtube.com/watch?feature=share&v=M91K_LPyX7k
Probably not for 2018 😉
Old 2018.12.08, 03:56 AM   #17
Interesting concept, but it looks like the implementation could be better. It would have been better if they showed the assembly, but it looks like a mono damper, but I think I would prefer it attached to the mount with a ball stud which would make it easier to remove for disassembly.
Either case, it looks like we might see a revised LM mount...
Old 2019.02.04, 05:38 AM   #18
Heres an update to that roll damper... also a new motor mount?
https://kyosho.amebaownd.com/posts/5653154 there's a video too
https://m.youtube.com/watch?v=13eb86...outu.be#dialog
Was wondering if there are subtitles in English... or if anybody can make out what he is saying...
Old 2019.02.04, 07:10 AM   #19
With the current r246 LM pod discontinued, this looks to be its replacement. As expected of Kyosho, it remains compatible with the stock LM rear suspension which is nice.
I’ve never used a tri-damper setup. Do you have any issues with the outside arms hitting bodies?
Old 2019.02.04, 12:09 PM   #20
New Audi RWD RTR
MINI-Z RWD Series Ready Set Audi R8 LMS 2016 “Gray/Red
No : 32323RGB
Technical Data
■Length 166.5mm
■Width 75.0mm
■Height 44.0mm
■Wheelbase 98.0mm (LL)
■Tread Wide
■Chassis RWD(MR-03)
■Motor Mount MM
■Front Wheel Offset Narrow+1.5mm(for RWD)
■Rear Wheel Offset Wide +1.5mm(for RWD)
■R/C System Syncro KT-531P
shop.tinyrc.com (Corrected): 10% off ALL MB-010 Products, 40% off Mini Inferno Bodies Mrs Mini-Z Newsletters 1 2012.04.20 09:36 AM
shop.tinyrc.com (Corrected): 10% off ALL MB-010 Products, 40% off Mini Inferno Bodies Mrs Mini-Z Mini-ZRacer.com Announcements 0 2012.04.09 12:14 PM
Kyosho mini z overland hummer h2 readyset monkey19 Mini-Z Marketplace 1 2010.08.12 09:32 AM
24 Hours of Le Mans = 24% off AutoScales!!! Mrs Mini-Z Promotions 1 2010.06.12 11:19 AM
