Old 2012.01.25, 12:57 AM   #1
BlackBerry
MR03 Low Down Knuckle Questions
I have a question regarding the MR03 Low Down Knuckles:
http://www.kenonhobby.com/PN-Racing-...e_p_42989.html
-Where is the 0.7mm taken off of? The top/bottom/both?
-Is the height of the axle pin moved?
I just want to know exactly how these are different from the stock MR03 knuckles.
Thanks,
BlackBerry
BlackBerry is offline   Reply With Quote
Old 2012.01.25, 01:00 AM   #2
PNracing
Send a message via AIM to PNracing Send a message via Yahoo to PNracing Send a message via Skype™ to PNracing
Thanks,
BlackBerry
The pin position higher 0.7mm. so it is low down 0.7mm.
http://www.pnracing.com
http://PNWC.pnracing com
DownloadPNICS ICS Android Apps for ICS Setting
PNracing is offline   Reply With Quote
Old 2012.01.25, 01:05 AM   #3
BlackBerry
So then the pre-load is not affected then? The overall knuckle has the same height as a stock one?
If that's so you might want to change your website's description. It actually states: "Pre load down 0.7mm".
Thanks for the quick reply,
BlackBerry
Old 2012.01.25, 03:02 AM   #4
AFAIK the knuckle has the same stack height as stock, just the pin has been moved upwards to lower the car.
Old 2012.10.05, 02:08 PM   #5
monkeyZ
The Race Dictator!
monkeyZ's Avatar
I have wondered this because when you combine the low down knuckles with the 1 degree upper arms there seems to be quite a bit of slop in the front suspension. To the point there if you don't put any shims in it the front springs can and do fall out. Does anyone else have this problem?
I will post pictures for reference when I am at my box.
I made a new thread as to not detract from the answer in this thread.
http://mini-zracer.com/forums/showthread.php?t=38419
monkeyZ is offline   Reply With Quote
Wheel bearings for pn low down knuckle? bevo Mini-Z Racer MR-03, MR-03 VE, Sports Series, EVO 5 2011.05.27 12:18 AM
Looking for low down knuckles (MR03) double_green Washington DC Area GTG, MD/VA/DC 7 2010.12.11 01:10 PM
New Atomic MR03 Alm. Knuckle Felix2010 Atomic 18 2010.05.11 04:48 AM
PN front low down knuckle Racer-HH Mini-Z Racer MR-03, MR-03 VE, Sports Series, EVO 4 2010.05.03 07:30 AM
MR03 Aluminum Low DOwn Knuckle PNracing PN Racing 11 2010.01.06 11:54 AM
