Old 2005.10.04, 02:34 PM   #1
PaulBoth
Last Place
PaulBoth's Avatar
Send a message via MSN to PaulBoth
Damper Plate Theory
Hey Everyone,
I've got an Atomic MM damper plate system installed. However, I'm looking for articles or an information source on what effect softer/harder springs have on the handling. Since it uses one above and one below, I really can't make out what effect having one hard and one soft lets say would do. Any help or direction would be greatly appreciated.
PB
P.s. I'm basically looking for a tuning aid, so if my car does this, try doing this type of thing. Thanks in Advance.
PaulBoth is offline   Reply With Quote
Old 2005.10.04, 05:06 PM   #2
byebye
byebye's Avatar
I personally haven't read any type of reviews or tips on the damper plate systems. Alot of people track tune. Personally It's helped my cars go much faster around the track. It was the missing link. I've personally found very tight gripped turning with the stock or softest springs. It was recomended.I use soft springs with a soft h-plate. I'm happy with it.
You can try searching the forums for atomic damper plate tuning.
-Byebye
Old 2005.10.06, 07:56 PM   #3
ruf
4play
ruf's Avatar
Quick tip: stiffer springs /more preload/more friction= less steering. Softer springs/less preload/less friction = more steering.
From Atomic:
Harder bottom spring gives fast steering response and on-power steering.
Softer top spring gives more off-power steering.
Joe Chen
www.reflexracing.net
Houston, TX
Mini-Z World Champions!
Reflex Racing Blog
Reflex Racing YouTube
Old 2005.10.07, 09:35 PM   #4
Ibrake Ifry
hey ruf i was looking on your website at the setup sheets and didn't notice the type of springs that were on the disc damper...i'll probably just track tune my damper anywayz
Ibrake Ifry is offline   Reply With Quote
Old 2005.10.08, 02:24 PM   #5
ruf
4play
ruf's Avatar
It's one of those things that changes from race to race. The stock Atomic springs are a good starting point.
Joe Chen
Houston, TX
Reflex Racing Blog
New pn 94mm motor- Does it fit the atm ssg 94mm damper plate system erixxst Parts and Hop-ups 6 2008.08.28 03:30 PM
Atomic 94 MM MM MM & Damper plate? Mocoloco Parts and Hop-ups 12 2006.08.10 09:01 AM
Damper Plate tuning ? Dustin Setups 18 2006.02.17 02:47 AM
Atomic Damper Plate System Fusion Mini-Z Racer MR-02 3 2006.01.11 02:13 PM
main damper and damper plate system PINCIR Mini-Z Racer MR-02 10 2005.09.23 04:06 PM
