Old 2010.11.30, 10:09 PM   #1
Mike Keely
Can FS be used with a GiroZ counting system?
We use to use FS for our track but the Core box broke. FS is so much easier for us.
Old 2010.11.30, 10:11 PM   #2
Action B
The Galliant Dude
I have a core box if you need. but I think giro-z is compatible but not sure.
Action B is offline   Reply With Quote
Old 2010.12.01, 10:39 AM   #3
pinwc4
pinwc4's Avatar
At this time Flip Side Software is not compatible with the Giroz. I would would like to add support but I will probably need to get access to the hardware to accomplish this.
Old 2010.12.04, 10:41 PM   #4
yscheong
I hope Flip Side can support Giro Z.
I have using core for few years, and with FS software.
Recently I have purchase a set of Giro Z for Pan car and F1 race purpose, my customer comment is the Giro Z is very quite and boring . No any announcement.....
yscheong is offline   Reply With Quote
Old 2010.12.06, 08:30 PM   #5
pinwc4
pinwc4's Avatar
I do hope to accomplish this. One thing that would really help though is having access to the hardware.
If someone were willing to let me borrow the hardware for a week or so I should be able to get it working.
Old 2010.12.07, 01:59 AM   #6
I-Lap
I have a complete system we took as a trade-in that I can lend you.
It is the USB model and there are a bunch of transponders with it. I don't have any disk or drivers with it, but they should be easy to find.
Email me your address and I'll send it out.
Craig
I-Lap Timing Systems
Precision Timing for Small Scale Motorsports
www.rclapcounter.com
I-Lap is offline   Reply With Quote
Old 2010.12.07, 11:08 AM   #7
pinwc4
pinwc4's Avatar
Craig
Thanks for the help, it is greatly appreciated. I sent you an email
Old 2010.12.07, 03:41 PM   #8
I-Lap
Mailed the box out today.
Something to consider going into this is the limited transponders. Unlike other systems where they are unique, Giro-Z is only 1 through 24 and are typically used as house loaners.
For small groups it may be possible to assign each racer a number, otherwise the software will need to be able to assign a house loaner before each race.
Old 2010.12.07, 04:17 PM   #9
pinwc4
pinwc4's Avatar
Awesome, thanks for the quick work on that, this will help tremendously.
You do have a very good point about the transponder id's. But I have started to work out a method to allow sharing within the software. The next release will include the ability to have multiple racers with the same transponder id. Only 1 racer with the shared transponder can be enabled at a time so when you switch it all you have to do is go to the edit racers screen and click enable for the racer that now has the transponder. So far in my testing it works well. In fact the build I recently emailed you about has this functionality in it already.
This will allow for loaners and for people to share there cars with guests but allow the guests to have there own id and results. I probably have a little more tweaking to do but it is close to complete.
Old 2010.12.07, 06:18 PM   #10
Action B
The Galliant Dude
As expected! A great feature if all goes well!
Old 2010.12.24, 09:07 AM   #11
Mike Keely
Any thoughts that it is possible?
Old 2010.12.27, 02:56 PM   #12
pinwc4
pinwc4's Avatar
It is possible but I am not sure if I will need to see the data from all 24 different transponder id's to accomplish it.
Craig from I-Lap was kind enough to loan me the hardware and 4 transponders. From what I have figured out so far the lap counter sends raw information to the computer and the computer decodes the information to determine the id. This is very different from any other lap counter, all the others send a packet of information that includes the specific id.
From the 4 transponders I have I have not been able to figure out an algorithm that would decode the data properly for all 4 of the ones I have. This leads me to wonder if I need to know the unique data stream that each id would generate and have that in the program to compare against.
Now that I know what I am looking for I could write a program to collect the data I need if other people have a lot of transponders that they could sample from.
Old 2010.12.28, 02:44 PM   #13
I-Lap
I had no idea it worked like that, so I only sent you the 4 transponders.
I also have 7 more, numbers 3,4,5,7,10,12,23 if you need them.
You may want to contact Jesus, the author of ZRound, to see if he can shed any light on this.
Craig
Old 2010.12.28, 10:00 PM   #14
pinwc4
pinwc4's Avatar
Thanks, I will try contacting him first.
Yeah I did not expect the serial data to look like that at all. There probably is a way to calculate the id it is just not obvious from the data I am getting from the 4 I have.
Old 2010.12.30, 08:59 PM   #15
pinwc4
pinwc4's Avatar
Craig
It looks like I need to take you up on this offer. I talked some with Jesus and while he did not know the exact details of the communication it did help me look at the data in an entirely different way.
The data does appear to be timing data representing the frequency, but the frequencies appear to follow an exponetial curve that I will need to calculate. More transponders will help me get a more accurate equation for this.
I appreciate you letting me borrow this equipment.
WTB Lap Counting System pfm racing27 Mini-Z Marketplace 0 2008.08.07 10:38 AM
WTB; core lap counting system Davey G Mini-Z Marketplace 3 2008.03.10 03:24 PM
FS: core lap counting system with 21 transponders wcrotty Mini-Z Marketplace 10 2007.12.21 01:36 PM
orion lap counting system question... ruknd@aol.com Off-Topic 9 2005.02.04 12:06 AM
Does KO PROPO's Mini-Z lap counting system work with iwavers? XCmdr Mini RC 3 2004.05.07 08:36 PM
