The "MINIZ Racer" is not only small and does not only give you a large-scale feeling, but it is also an unprecedented new generation palm-sized racer. It comes with a newly developed receiver with built-in amplifier plus a micro servo, all installed in a 90mm-wheel base chassis. In addition to this, the amplifier is a FET high frequency type that provides high power. Also, the receiver is 27MHz-narrow band-ready and allows for up to 12 cars to run simultaneously. A long running time of about one hour is also possible with only four AAA alkali batteries. Sleek racing with a 3P suspension 130-class high power motor and differential gears makes it possible to enjoy "Racing Everywhere". In addition to the authentic chassis performance that only KYOSHO can produce, various optional parts allow for further racing improvements. The portability and authenticity of the "MINIZ Racer" will raise the standard of R/C racing to unprecedented levels.
Chassis Technical Data
Length 130mm
Width 65mm
Track(F/R) 56.5mm
Tyre Size f 25 x 8.5mm
Wheelbase 90mm
Gear Ratio 7 : 1
Battery(notincl.) AAA-Size x 4
Motor(incl.) 130 Type
Controller(incl.) FET HF Type
Features
A sophisticated independent kingpin front suspension with front stabilizer bar produces realistic handling. Strong steering servo realizes precise control characteristics.
The solid rear axle is controlled by a flex-type suspension for optimal handling. Proper rear differential provides smooth power delivery.
Chassis Configurations
RM chassis/ Rear Motor Mount: On the RM chassis, the motor is mounted behind the rear axle. Positioning the C of G at the rear produces high levels of traction. This makes tail control all the more interesting. RML chassis omits the top damper to generate lower chassis height for the RM chassis.
Electronics Configurations
Standard AM radio system combines the receiver and speed control for efficient running and precise control.
Special Editions
N/A, however -- there are Chinese-made and Japanese-made Mini-Z MR-01 cars. The Japanese ones are reputed to be of higher quality in both plastics and electronics.
MR-01 STOCK PARTS KITS
No. MZ1 MAIN CHASSIS SET
No. MZ2 CHASSIS SMALL PARTS SET
No. MZ3 MOTOR CASE SET
No. MZ4 SUSPENSION PARTS SET
No. MZ5 DIFFERENTIAL GEAR ASSEMBLY
No. MZ6BK PINION GEAR SET BLACK
No. MZ7 METAL PARTS SET
No. MZ8 R/C/ UNIT SET
No. MZ8-1 SERVO GEAR SET
No. MZ8-2 SERVO CASE SET
No. MZ9 MOTOR SET
No. MZ10 ANTENNA
No. MZ11 PYLON SET
Images are property of Herman C., used on this page with permission.
Text is property of Kyosho Corporation, and used on this page only for informational purposes.
