Old 2010.09.02, 09:32 PM   #31
great collection arch2b... wondering... while using for them for 10 years... did they develop any kinks or dents? like has durability ever been an issue while racing? i ask because most of mine are on shelf queens...
thanks for posting guys... squares really complete the look of these autoscales...
just lovin it...
Old 2010.09.02, 09:52 PM   #32
i did manage to put a good nick in the outer rim face of a pair by running a modified mr-02 outside on asphalt and loosing the car in a pot hole a couple inches in size. enough to swallow the car. the front wheel hit the other side at just the right angle at absolute full speed. i kept using the wheels and just took a nail punch to tap the nick back out.
the common worry is they are delicate. i can attest to my personal experience that they are indeed very durable despite the delicate nature of the design. i've bent/broken far more plastic wheels over the years.
Old 2010.09.02, 10:48 PM   #33
i think i do remember reading that fateful incident a couple years back... and it's nice to know that durability as well as looks are indeed a quality that one will consider when getting these rims...
found more pics...
Old 2010.09.03, 12:41 AM   #34
some more...
Old 2010.09.03, 12:42 AM   #35
Old 2010.09.03, 03:39 AM   #36
kinda looked at this (rear wheel wells against rear tire orientation) and figured that the body might be actually designed for a 96mm setting (presently its at the L - 94mm setting)... don't really know if the real thing is designed or supposed to look this way...
Old 2010.09.03, 05:49 AM   #37
deanoliver
deanoliver is offline   Reply With Quote
Old 2010.09.03, 05:53 AM   #38
deanoliver
Ciao, Olli
Old 2010.09.03, 07:02 AM   #39
thanks for sharing deanoliver... great pics
Old 2010.09.03, 09:43 AM   #40
Mrs Mini-Z
Administrator
Originally Posted by Pierro View Post
Those wheels are so beautiful...
Only problem is to find a (web)shop to buy those...
Just wanted to mention that while doing inventory recently we found a bunch of Square wheels that needed to be added to shop.tinyrc.com. They are available now! Check them out and maybe we have what you're looking for!
Mrs Mini-Z is offline   Reply With Quote
Old 2010.09.03, 11:57 AM   #41
I have some Osian Tagu wheels for sale in my For Sale Thread if anyone is interested:
http://mini-zracer.com/forums/showthread.php?t=34776
Old 2010.09.03, 12:00 PM   #42
color01
color01's Avatar
As arch has said, despite their appearance the Squares are actually very tough wheels. My current set has seen two races, and I don't see any dents; as soon as I clean the dust off they should look good as new. The thing about Squares vs. any plastic wheel is that the hub is NOT a weak spot: you might manage to nick the face or the lip if you're traveling at insane speeds outdoors, but you'll never break the outer rim from the hub, and hence you will never DNF due to breaking a wheel. All you have to do is fix the dent.
If you're considering using these as dedicated racing rims -- which is perfectly fine considering their weight and quality -- my only advice is to not glue directly to the aluminum if you want to keep your wheels looking nice. Wrap two layers of Scotch tape (translucent, standard type) around each wheel, cut off excess tape with a knife, then glue the tire to the taped rim. Also makes tire removal very easy, just rip it off. No need to cut into your rim.
Brian Ma
Greyscale RC
PN Racing | My TinyRC Blog
Old 2010.09.03, 05:59 PM   #43
ub0211042
ub0211042's Avatar
Originally Posted by deanoliver View Post
does this wheel comes in this color or u somehow painted it?
Mini-Z AWD 2.4Ghz 94mm
Mini-Z AWD DWS PN A-Arm 2.4Ghz MR03 board 98mm
Mini-Z MR-02 2.4Ghz
Mini-Z MR-03
FX-101 Dnano 360 Modena
ub0211042 is offline   Reply With Quote
Old 2010.09.04, 02:27 AM   #44
deanoliver
I painted them.
Olli
Old 2010.09.04, 06:12 AM   #45
ub0211042
ub0211042's Avatar
I painted them.
Olli
looks really great and goes well with the mclaren , how do u paint em? and will it chip off?
Mini-Z MR-02 2.4Ghz
Mini-Z MR-03
FS: Square MR-02 Alum. Rims SKM-007IM Old Crow Mini-Z Marketplace 2 2009.10.05 04:14 PM
FS: Square Silver BBS Rims faydoiinspire Mini-Z Marketplace 30 2008.02.19 08:15 PM
Kyosho aluminum rims ~VS.~ Square aluminum rims G'ZOX Mini-Z Racer MR-02 7 2005.08.15 08:31 PM
Square CLK front rims seems to be a bit loose..... Skylineboy Setups 6 2002.09.07 08:49 AM
