Old 2013.02.08, 07:12 PM   #1
Mike Keely
Looking for +2.5 front rims???
MR02 or 03 front rims. Does any aftermarket company make any? If not, how do I know what Kyosho rims are +2.5 rims? Thanks guys..
DG-Designs / Brooklyn Hobbies
Mike Keely is online now   Reply With Quote
Old 2013.02.08, 07:17 PM   #2
blt456
I know that PN and Atomic don't sell 2.5mm fronts. However, I don't see why you couldn't put a 0.5mm shim on the knuckle to space the inner front bearing in a 2mm front wheel.
blt456 is offline   Reply With Quote
Old 2013.02.08, 10:26 PM   #3
TheRinger
THATS HOW I ROLL
TheRinger's Avatar
Only wheel I can find is the R246 RAYS CE28 wheel in 2.5mm narrow here at the shop.
The only other option is if you can find the complete kyosho wheel set for MR02.
It does front wheels in offsets of 0, 1.5, 2.5 and 3.5mm. Rear wheels in 0, 1.0, 2.0 and 3.0mm. That's all I can find. I thought that atomic made the S6 wheel in that offset but I guess they don't. Also if you can find the Ferrari 575GTC wheel set, the offset is 2.5mm front and 3mm rear. The wide McLaren F-1 uses the same wheels. The porsche 935 are of the same offset but the rear wheel diameter I think is 23mm. Not exactly sure but I know the rear wheel is bigger in diameter then the front. Or just get the 599 wheels which are +3 front and rear. Or any aftermarket wheel in +3 offset. Sorry that's all I can think of. Or just shim it like blt456 suggested.
Awesome RC Racing R.I.P
Old 2013.02.09, 12:19 AM   #4
HammondCheese
+1 to shimming a +2 offset for giving you the biggest choice. You might want to investigate further but I THINK the fronts for the long nose McLaren are +2.5s though.
HammondCheese is offline   Reply With Quote
Old 2013.02.09, 02:13 AM   #5
MXMRCR
MXMRCR's Avatar
RAYS MR-02 multi offset wheelset has a +2.5 front, i know because i use them on my Molsler...expensive way of getting 1 pair of front wheels tho.
NoWayPedro
#BTRR
MXMRCR is offline   Reply With Quote
Old 2013.02.09, 07:01 AM   #6
The old 575GTC Pasta Rocket used 2.5 fronts. That is the only listing on the old A/M compatibility chart that I could find.
PN MR03 Front Double A-Arm Suspension Coming Out? Felix2010 PN Racing 50 2011.10.10 11:29 AM
track width comparison... herman Mini-Z Racer MR-02 22 2003.09.24 06:05 AM
