Old 2019.02.12, 04:17 PM   #1
LJH
Freeing up ball joints
Hello All,
I just installed the Kyosho MZW416 tube shock front end on my 90MM MR03 and it seems to have helped a bit as the car now holds the all time lap record on my mini-96 tracks. With that said I am still not happy with how free the balls are in the front arms. I went as far as using a very mild polishing compound and turning a kingpin in a drill in the hopes of loosening them up and while it got a bit better it is not terribly free.
How do you guys go about freeing up the ball joints on your Mini-Z's?
Cheers,
Jim
LJH is offline   Reply With Quote
Old 2019.02.12, 04:41 PM   #2
cowboysir
I've done the same thing (drill mounted) with Mothers Metal polish and that did the trick for me.
my custom body album...
Old 2019.02.12, 04:47 PM   #3
LJH
Copy that, I may just have to get more aggressive with the compound. I used McGuire's Scratch-X which is very mild.
Thanks.
Cheers,
Jim
Old 2019.02.12, 07:04 PM   #4
I've read a tip somewhere... invert the kingpins...
Haven't actually tried it, but it might help...
Old 2019.02.12, 09:06 PM   #5
LJH
I have been running inverted kingpins pretty much fo day one.
Cheers,
Jim
Old 2019.02.12, 09:15 PM   #6
Mothers polish, and keep the duration of polishing relatively short. You want to minimize heat when polishing. Break it up into 5s spin and cool cycles, If you can reverse the direction the pin spins when polishing.
I find that if you get the plastic too warm, it will loosen up momentarily, but after cooling it is tight.
Old 2019.02.13, 06:24 AM   #7
will3kgt
Cheers,
Jim
Me too, never had a problem.
will3kgt is offline   Reply With Quote
MR03 Ball Joints ShortBus Mini-Z Racer MR-03, MR-03 VE, Sports Series, EVO 9 2018.12.15 09:28 PM
Ball diff changes... HaCo Mini-Z Racer MR-02 4 2007.07.15 04:26 PM
unnamed ball diff setup with bearings bendalf Setups 4 2002.07.22 06:46 AM
Ball diff problem bobman Parts and Hop-ups 15 2002.03.01 10:32 PM
Ball Diff Ball Diff Ball Diff Ball Diff II Chezedog Mini-Z F1 MF-010, MF-015 1 2002.02.27 03:40 PM
