Go Back   Mini-ZRacer.com Forums > Manufacturers > Kyosho
Old 2019.03.28, 06:48 PM   #1
Smokey_truck
Guest
Posts: n/a
Formula board swapped from AM to Dasmikro ASF
I swapped Formula board from AM to Dasmikro ASF, only two wires are wired to pot but pot wire is bridged to 3v side, steering is not working good, either turns left or right not progressive like regular miniz. Is there any advise I can have to solve the issue.
Smokey
Old 2019.03.28, 07:45 PM   #2
You need to run 3 wires. AM used an analog arrangement with 2 wires, where the ASF uses a more precise digital arrangement. When you wire it up, if the center wire (wire 2) goes to the 2nd pad on the board. Wire 1 and 3 go around it. If the servo pulls away from center, then reverse wires 1 and 3 and servo will center. Then reverse the steering channel if needed. If steering is reversed and you do not want to reverse the steering on the radio, you would need to swap wire 1 and 3 as well as the servo motor wires.
Hope this info helps.
Old 2019.03.28, 08:16 PM   #3
Smokey_truck
Guest
Posts: n/a
Thanks EMU, initially I wired that way, unfortunately the servo motor kept running, after disconnected the wire it stopped. So I bridged the middle one and one side of the pot. Not sure why servo motor is running without doing anything on the controller when 3v is connected to one side on the POT. Any ideas?
Smokey
Old 2019.03.28, 08:41 PM   #4
A picture or diagram of how you have it wired would help diagnose it.
Old 2019.03.28, 09:23 PM   #5
Smokey_truck
Guest
Posts: n/a
See the picture, excuse two green wires, could not find more of such thin wires anywhere
https://photos.app.goo.gl/4HCUriCBNyteP7ZG7
Old 2019.03.28, 09:47 PM   #6
If the servo is not in the assembly, and pot is not fully centered, the motor will run trying to center. You know when the pot is wired directly when you rotate the resistor past center and the motor switches direction.
Old 2019.03.28, 10:08 PM   #7
Smokey_truck
Guest
Posts: n/a
Well when it was in the pod, it was not doing anything, was there a different pot used in old board and do I have to use a different pot for newer asf boards? Just trying to remove all variables.
Thanks again for your help
Smokey
Old 2019.03.28, 10:56 PM   #8
Pretty sure it's the same pot used in both.
Old 2019.03.30, 03:57 PM   #9
cowboysir
Have you tried swapping the servo motor wires? dasmicro asf boards are expecting an 03 servo motor and I have had motor running issues when mis -wiring an 02 type servo motor onto an asf style board.
my custom body album...
Old 2019.03.30, 05:38 PM   #10
Smokey_truck
Guest
Posts: n/a
It is funny, board has M+ and M- but the picture in the description in excel EC shows opposite, I do not want to smoke the board, I already had problem with one so this is second board. I will try and see, just will run opposite direction which anyway I reversed in the controller.
Smokey
Old 2019.03.30, 08:12 PM   #11
Try putting it all together with the gears in.... here's my theory, I believe the servo motor will keep spinning if there isn't any resistance from the pot that will keep it centered (hope somebody can confirm this)...
I plan on doing the same thing.... converting an am f1 to asf by swapping out the board and using a das mikro board... so I'm pretty interested and watching closely here... my questions are pretty much the same pertaining to wiring the pot and servo motor...
I might also have a spare mr03 board that I can use... question... if I do use the mr03 board, i only change the servo motor right?
Hope this helps... and good luck
Old 2019.03.31, 08:03 AM   #12
Im not at home, but have this image on my phone... it is ASF mr03 pcb, you can just see the wiring.
This is my only mr03 PCB in an f1.
Old 2019.03.31, 07:42 PM   #13
Interesting set up...
A couple of questions...
- apart from changing the servo motor to the bigger ones being used in the f1 and mr02/15 and adding an additional wire on the pot, did you change the wiring orientation? Or is the f1 wiring basically the same as the mr03 board?
- front end including upper arms looks pretty much close to bullet proof... who makes them?
- rear end is pretty interesting too... shock system, motor mount, diff all the way up to the rear wing...mind telling us who made them?
Lastly how does it perform? Would love to see any videos...
Old 2019.03.31, 08:34 PM   #14
This car was made 9 years ago. MantisWorx arms, bumper, tri damper. Matt Ward drove it in the 2010 PNWC Finals finishing in third place.
Not sure if the wiring needed to be reversed for the servo. It was so long ago that it was developed.
Old 2019.04.01, 01:21 AM   #15
Woah... cool... 9years ago eh? 3rd place in 2010 too?!?!!!!
Thanks for sharing... kinda miss running my f1...
Tags
formula servo
ASF AWD vs. MR03 board herman Transmitters, Receivers and Crystals 9 2019.01.31 05:59 PM
shop.tinyrc.com: Holiday Savings Start Today & End In 2014! Mrs Mini-Z Mini-ZRacer.com Announcements 0 2013.11.27 09:34 AM
shop.tinyrc.com: Holiday Savings Start Today & End In 2014! Mrs Mini-Z Newsletters 0 2013.11.27 09:33 AM
Pin outs Diagram of 02's ASF Board? machgo5go Mini-Z Racer MR-02 1 2011.01.04 08:48 PM
Weird ASF board... cowboysir 2.4GHz ASF System (Auto Selected Frequency) 12 2008.12.20 04:50 AM
