Old 2020.05.09, 10:48 AM   #1
ZRound V1.20 Build 11
OK, installed 1.20.11 (from v1.20.09) and again, all the sound files are missing. Text to speech is there but no audio files. Can I extract these files from older version to wherever they are supposed to be located?
Old 2020.05.10, 04:19 PM   #2
zround
Send a message via Skype™ to zround
I can't reproduce the issue. Updating old release and installing from scratch gives me the sound options with the expected settings (on both sound and speaker tabs).
Anyhow, the sound files are saved into the "resources" folder under the application installation path. On a Windows 10 typical installation should be "C:\Program Files (x86)\ZRound\Resources".
In your other post I've seen a text is still in spanish into "Speaker" options. Please use the the "Default" button to set the default text on your language.
See http://mini-zracer.com/forums/showpo...16&postcount=8
zround is offline   Reply With Quote
Old 2020.05.10, 04:52 PM   #3
Is there a cheat sheet to correlate mapping the sound files to the action? I checked the folder location and they are there but not mapped it seems from the Sound tab.
Old 2020.05.11, 07:01 PM   #4
zround
Try this ...
Sounds 1
Unregistered car.... resources\alarma.wav
Suspected reading... (disabled)
Finish line pass.... resources\count.wav
Lights.............. resources\count.wav
Staggered start..... resources\prestartbeep.wav
LapZ Bridge Alarm... resources\ding.wav
Race finished driver (disabled)
Race starts......... resources\init.wav
End of race......... resources\init.wav
Time finished....... (disabled)
Sounds 2
Better own time..... resources\veloz.wav
Best lap............ resources\best.wav
First rank.......... resources\bocina.wav
Track best lap time. resources\sirena.wav
Best own time....... resources\personal.wav
Best lap target..... resources\target.wav
Old 2020.05.11, 07:20 PM   #5
perfect, solved the problem.
Old 2020.05.14, 04:54 PM   #6
zround
Next release will have a "Default" button on the sounds page to reset values to this "factory settings" sound configuration.
ZRound v1.18 Build 1 and Robitronic USB NoBrainer ZRound 9 2019.06.25 04:02 PM
ZRound Suite 1.15 build 6 NoBrainer ZRound 12 2016.10.30 09:37 AM
ZRound 1.12 build 24 NoBrainer ZRound 6 2014.12.29 03:36 PM
ZRound Suite update 1.10.10 zround ZRound 1 2011.09.14 02:06 AM
ZRound Suite 1.9 zround ZRound 10 2010.02.19 12:25 PM
