Old 2020.05.20, 02:32 PM   #1
pfcparts
FS: ASF F1s some other stuff
1. Name - Khang
2. Location - Chula Vista
3. Contact – ooragnahk@hotmail.com or pm here
4. Description - AM F1s that were modified with Kyosho ASF F1 boards
5. Price – asking $390, $340 (not stern)
US only unless I have shipped to you before and you are still in the hobby lol.
I am not sure what is running now FHSS? You will need a newer ASF backwards compatible controller, KT18 controller, or a controller with a kyosho module RF-901SM to use this.
AM F1s modified to ASF using kyosho F1 boards. First gen ASF boards so I don’t think they have the useless Tiki Tiki feature, but it has been way too long for me to remember. If I recall correctly there was a different servo and case set up hence the mismatched chassis colors.
Will not part out items. Some of this stuff is pretty stupidly expensive or impossible to find now. Looking at you K diff and Ti shaft lol.
Shu
PN ceramic bearings (dried)
PN Ti M2 machine screws where possible
K alloy knuckles (1deg)
K tierod set
K kingpins
K front springs
K rear springs
K carbon plates (M)
K shock
K diff w/ ceramics and Kyosho Ti shaft
PN F1 mount
TSM 33t 44.1k 1.14 amps
Square alloy Gold Enkei (F: K30/R: K20)
ATM red lugnuts
https://imgur.com/a/sspIc1O
$390 shipped
Mcl
K alloy knuckles (2deg)
K kingpins
K front springs
K rear springs
K carbon plates (M)
K shock
K alloy motor cover
K xspeed? motor
K alloy Silver Enkei (F:K30/R:K20)
3Racing locknuts
https://imgur.com/a/dxaBuQO
$340 shipped
Not too stern on pricing so shoot me a serious offer if you like. I will be adding some more older ASF chassis', rare older ascs, dnanos, rare whitebodies and stuff to thread once I figure out what is on these things and take inventory again before the move. Ideally I wish to get rid of enough items to only worry about one box (or less!) of this stuff during moving. Will post here before I eventually list most items on craigslist or scummy ebay.
Will include K tierods, springs front and rear. If I have the stock motor pods and wheels they will be included. Should still have some squat FRP plates somewhere that I will include as well.
Tested in hand each once after conversions to see if they worked properly and could steer. They've been sitting in closet for last few years so a change of rubber, diff clean/grease, and balancing the side plates is probably a good idea. Will test again in hand before they go out.
** Just realized there is a crack on the front on the Shu while posting pictures. Hasn't fully cracked through, but the posts are extremely close to the front edge which means they will probably crack on both sides eventually from them being pressed in during install and due to aging. If you hit anything at any speed with these damn fronts they will be obliterated. That red body is just so delicate. Just be mindful of that.
Cheers.
pfcparts is offline   Reply With Quote
Old 2020.05.24, 02:30 PM   #2
pfcparts
787 bodies and dnanos
Bodies: Asking 45 shipped each unless you prefer it shipped in a small flat rate box. Danger there is they might crush it.
https://imgur.com/a/mOW8VyR
All should have clips, if not I'll knock off some. No wheels unless I magically find them somewhere. Didn't leave clips and wheels with body to not damage them, but have no idea where they are at the moment lol. Hopefully they are together in a bag somewhere when I check on everything else.
Mini Z world cup: Looking for 250
https://imgur.com/a/UH3XNat
Collectors item. No board unlike the anniversary F1 or F1 carbon. I wish I kept those F1 preorders lol. Those are stupid rare now.
ASF Dnanos: Looking for around 275ish each.
911
All kyosho hop ups except for the heavy type two top cover. (medium plate I think) Will include kyosho springs option parts as well. K diff has ceramic balls. Will also include working battery. F:30 R:20
***911 does not have the sticker for kyoshos lap under track counter on chassis. I am not entirely sure if I have it.
https://imgur.com/a/9TXWead
Murc
All kyosho hop ups except for the heavy type 2 top cover. (also medium plate) Will include kyosho springs option parts as well. K diff has ceramic balls. Will also include working battery. F:30 R:20
https://imgur.com/a/x4wHNCC
DBR
Type 2 heavy battery cover. Everything else is stock. Will include F:30 R:20 tires. Not sure if they are any good still though. Includes medium plate and dnano xspeed motor as well. No K springs unfortunately.
I have atomic diff and disc damper set for this I will include. Never put them on for some reason. I do not know if the atomic diff is any good. K diffs are great though. Will include ceramic balls as I assume they are same size as K diff balls. Will also include working battery.
https://imgur.com/a/auwXLOh
I have a battery charger as well but will only let it go if everything else is gone.
I have an extra type two cover and wheels that I can include in first dnano sale if it happens.
Maybe list some more stuff but if not I'll just list some rare whitebodies no reserve on ebay soon and let you guys decide on price lol.
Have a great and safe weekend.
FS (3)Pre-owned ASF MR02 chassis+body and MR02/MR015 parts lot bobbyz Mini-Z Marketplace 5 2020.02.14 11:14 PM
shop.tinyrc.com: Holiday Savings Start Today & End In 2014! Mrs Mini-Z Mini-ZRacer.com Announcements 0 2013.11.27 09:34 AM
shop.tinyrc.com: Holiday Savings Start Today & End In 2014! Mrs Mini-Z Newsletters 0 2013.11.27 09:33 AM
mr02 am switching to... (asf vs ex) herman Mini-Z Racer MR-02 14 2013.02.12 06:28 PM
Kyosho Mini-Z MR-02 LM 2.4GHz ASF Pre-Order arch2b Mini-ZRacer.com Announcements 0 2008.01.20 05:02 PM
