Old 2009.12.22, 09:22 PM   #1
jjay
jjay's Avatar
Send a message via AIM to jjay
TrXus MT Super Swamper Tires
anyone know if these TrXus MT Super Swamper Tires I found on ebay can be used with the overland? Also, what kind of rims will be needed to make these work (if they are even scaled well enough for the overland)?
ebay item # 200420868630
whatever the case, i'm looking for some bigger/beefier tires for my overland if anyone knows where i can get some.
thanks a lot!
-JJ
jjay is offline   Reply With Quote
Old 2009.12.22, 09:29 PM   #2
only way to tell would be to know the inside diameter so that they could be paired with an appropriate diameter mini-z wheel, more than likely a racer wheel unless you want to bead glue the sidewalls to overland wheels.
Old 2009.12.22, 09:36 PM   #3
Dr. Kustom
Dr. Kustom's Avatar
Send a message via MSN to Dr. Kustom
Item number: 160388380915
Try those, they have good grip and they are HUGE!
GSR / Atomic
Dr. Kustom is offline   Reply With Quote
Old 2009.12.22, 11:23 PM   #4
jjay
jjay's Avatar
Thanks for the link kustom. and yea I just realized racer wheels fit on the overland! never thought about that, thanks arch! should be easier to adapt random wheels to a flat racer wheel than the overlands inner rim.
I kind of want to stay away from the "Monster" look. The stock wheels are really puny looking, I'm looking for something a bit wider and thicker in diameter.
Maybe i'll just grab the ones I found and see if they work, only like 6 bucks anyway.
In the meantime i'll look around a bit more and see if anyone else here pops up with info.
Old 2009.12.22, 11:30 PM   #5
jjay
jjay's Avatar
oh duhh i just noticed the dimensions on the details.
blah the wheels seem a bit too big for me.
Dimensions:
Height - 1.845"
Width - 0.730"
Mount hole - 0.826"
the search continues...
Searching Super U Swampers and Mini Pin Tires diets Mini-Z Overland MV-01 10 2006.08.09 02:40 PM
Do you need Swampers? Swamper Trials held DogbreathRacing Mini-Z Overland MV-01 12 2004.01.07 12:42 AM
Super U Tires, which Rim? Newbster Mini-Z Overland MV-01 13 2003.12.02 11:17 PM
Squat F1 Foam Tire Review dwi116 Mini-Z F1 MF-010, MF-015 6 2003.03.19 10:11 PM
GPM Foam Tires in shop...anyone have problems? MetaOrbit Parts and Hop-ups 7 2002.01.13 07:50 AM
