Old 2016.11.08, 02:25 AM   #1
rojak
rojak's Avatar
MR03VE vs MA020VE
Hi,
I saw both board physically same, is there any difference except to use car type?
Regards
MR01->MA-020VE->MR02-VE>MB010
rojak is offline   Reply With Quote
Old 2016.11.08, 11:40 AM   #2
TheSteve
VE7FM
As far as I am aware it is only the software in them that is different. The software change is for the steering servo.
You can use the 03 board in an AWD if you have a transmitter to turn the end points way up. Putting an AWD board in an 03 will lead to very poor steering performance even with transmitter adjustments.
Old 2016.11.08, 08:58 PM   #3
rojak
rojak's Avatar
Well that explain, because currently using AWD VE board on MR02. Any suggesstion to hack the software?
MR03VE build with JesseT's side rail chassis ianc Aftermarket Chassis 9 2016.10.26 01:48 PM
ma020ve questions 0100 Beginner Questions 5 2016.02.11 09:35 AM
MA020VE brake 200sxr Mini-Z AWD MA-020, MA-020 VE 4 2015.07.10 10:31 AM
Brushless MR03VE on AWD chassis? rodolfosolis Mini-Z AWD MA-010, MA-015 30 2014.04.09 12:02 AM
Damper set on mr03ve kunming X-Power R/C 4 2013.05.09 07:58 AM
