Old 2018.12.28, 05:59 PM   #46
Need to know if the MZ601 board will fit? Then can interchange brushed/brushless and receiver.
Old 2019.01.04, 08:58 PM   #47
ghost chili
I just received one over the holiday season. Great fun. I like how it is compatible with the AWD chassis parts, so I was able to swap over some parts from a busted AWD chassis I had lying around. So far, I've got a 50t PN Racing BB motor with the stock gearing, the DWS rear end I swapped over from the AWD chassis, and the gyro unit.
Packed up the stock gear diff with some Tamiya hard friction grease to limit the diff action and it pulls pretty well on my carpeted basement floor with the stock tires. I ordered the Civic Type-R but swapped over to the Golf R32 I had from the AWD chassis so I wouldn't mar up the clean Civic body. Thinking it would be great to swap the board to ASF so I can continue using the EX-6 radio I'm already using for the other Mini-Zs I have.
ghost chili is offline   Reply With Quote
Old 2019.01.11, 09:38 PM   #48
Welcome to the forums... Let us know if you do make the swap... looking forward to see what you did.
shop.tinyrc.com: The MR-03VE PRO RC Chassis Set Is Finally Back In Stock! Mrs Mini-Z Newsletters 0 2016.02.03 12:11 PM
Finally make252 Mini-Z Overland MV-01 2 2006.04.21 07:33 PM
finally!!! Mzfreak Miscellaneous Discussion 5 2006.03.01 10:55 AM
finally some hop-ups Dempy Parts and Hop-ups 3 2003.01.26 08:16 AM
Modena, Finally Drives Adult_driver Setups 10 2003.01.18 02:24 PM
