2006.06.20, 02:22 PM
#16
Bogus nachos
If improper here delete as needed but I have a some used RCP I just purchased from our original club members. I have since gotten a ton of my own so this is just extra track. I currently have some small add on turn kits on Ebay for sale but can also put together something larger custom kits if you like. I also have some homemade inside turns I can sale also. madf1man@sbcglobal.net
2006.06.20, 04:08 PM
#17
fast and out of control
noob
it seems were still on the same debates/questions...I made my own then bought an RCP. Save yourself teh time and $$$ and just go get an RCP.
2006.06.20, 09:45 PM
#18
To follow up, I did buy the Ebay track surface, I understand that rcp is the better product, but I really like the idea of having a COMPARABLE surface to which I can build my own track. I assume one day I will proboalbly eat those words, but what the heck lol. Thanks for the thoughts and for still bieng posotive about home built tracks, its nice to know that you guys have been where I am.
It is a big jump going from all 1/10 stuff to 1/24, but im hopefull it will be fun and easier on time constraints and $$$. I will keep you guys updated on the status of my track and post some pics of progress for sure, it should arrive thursday!
2006.06.20, 11:02 PM
#19
Team ShoBoi
Hey guys, I need help too. I'm about to make a track for my own use in the basement so it is sort of permanent. Would I be better off with those foam mats I can get at WalMart? Here is a picture I found from the forums that some guy did and I think it is excellent and will use the same material for mine. What do you think? Is this a cheaper alternative since I'm on a budget?
Thanks.
2006.06.20, 11:41 PM
#20
these mats don't have the great surface that the RCP tracks has but they are a good surface. you will want to go with a soft tire compound and I highly recomend the foam barriers. you can use pvc and clip the pipe foam over them to protect the cars.
if you budget won't allow for the RCP, it is a great option, and still more configurable than a carpet track.
I say go for it.
#21
Those look like the same exact tiles I ordered. Looks like that guy has a sweet setup to me, but as it was said before, RCP is the better track....
2006.06.21, 12:50 AM
#22
Thanks.
Well, if you’ve made it this far down the thread you have already heard the unanimous recommendations to skip the DIY step and go directly to the RCP if at all possible.
When it comes to making your own in the best of all possible situations you would have driven on and tried out several different tracks, deciding on the type/style that would work for you. For example I would have difficulty with the track in the photo; to start with my cars would plow right through and under the railing as shown eventually tearing the twist ties right out through the foam, also do to the slickness of the untreated surface I wouldn’t be able to get up to any satisfying speed even if the lanes weren’t a little narrow especially for the slick surface and easily bashed around rails. But that would just be my opinion for me.
If you’re determined to go with foam mats I would first suggest setting them up without rails and drive around on them first, that will give you an idea about the surface. If you want/need more traction 80 grit sand paper to scuff the surface followed by a light coat of chalkboard paint is one option. Once you’ve come to terms with the driving surface you can start on the rails. With the rails again I suggest you do a little experimenting before making any sort of irreversible investment and/or installation. Another problem will be deciding on lane width which will also be dependent on what you decide on for rails, if you are planning on more than one or two cars driving at a time and/or higher speeds two feet can be just a little confining.
Jungle Outlaw Micro Racing
2006.06.21, 10:22 AM
#23
Team ShoBoi
Hello,
Thanks for your advice. Just wondering, are these foam mats really that bad traction wise? I tried this surface before at a friends house and it was hooking up with just Atomic grooved tire, and I think GPM tires would be even better.
Thanks,
2006.06.21, 10:51 AM
#24
Hello,
Thanks,
I used them (the ones from Sam's Club) and they had pretty good grip.
2006.06.26, 12:16 AM
#26
yes, it's a boxer
Originally Posted by steiner9
track looks great...good work!
