Old 2008.11.16, 12:29 PM   #1
lugnutz
lugnutz's Avatar
ics not comunicating with car help please
i bought the ics from kenon and i don't seem to be able to get it to work
i think i'm missing something,
1]do you have to have batteries in the car
2]do you have to have tx on
3]when i try to close program it won't unless i use task mgr
i did get the light on the car to come on dim,but still nothing loads or reads any help would be appreciated
an eye for an eye will make the whole world blind
lugnutz is offline   Reply With Quote
Old 2008.11.16, 12:57 PM   #2
yasuji
PN RacingTEAM Driver
yasuji's Avatar
Send a message via AIM to yasuji Send a message via Yahoo to yasuji
lug
you need to:start the program ,set the com, hook it up with no batterys tx and switch off and then hold the bind button toll the light comes on solid
Grant "Yasuji" Matsushima
www.pnracing.com
gm@pnracing.com
yasuji is offline   Reply With Quote
Old 2008.11.16, 03:47 PM   #3
lugnutz
lugnutz's Avatar
thats the step i missed thank you yas
how was your awd
Old 2008.11.16, 03:59 PM   #4
yasuji
yasuji's Avatar
how was your awd
so far so good..... i tried the oneway first but every time i turned while hard in the throttle it got flicked end over end
so now i have diff in the front and rear 94 mm with a nsx body like tj but i needed to install the wing.... the rear was way to loose
awd seems easy to drive.... i can be aggressive and it steers better on throttle
ididnt have to change my drive style too much
every thing is new and has too much engine braking/frictional loss.... seems slow compaired to my pan.... i will be working on some friction reduction today
www.pnracing.com
gm@pnracing.com
Old 2008.11.16, 04:07 PM   #5
lugnutz
lugnutz's Avatar
thats good to hear but i still think if you can get the front end stiff enuff the one way will work to your advantage
Old 2008.11.17, 03:14 PM   #6
lugnutz
lugnutz's Avatar
i tried whay yasuji said to do and still have a no communication error pop up please anything else i might be missing
Old 2008.11.17, 03:25 PM   #7
yasuji
yasuji's Avatar
what does the error say
www.pnracing.com
gm@pnracing.com
Old 2008.11.17, 03:41 PM   #8
lugnutz
lugnutz's Avatar
when i push program it comes back saying did not communicate
Old 2008.11.17, 03:43 PM   #9
lugnutz
lugnutz's Avatar
oh and when i go to close the widow it will not close unless i go to task mgr to end task
Old 2008.11.17, 03:52 PM   #10
yasuji
yasuji's Avatar
r u using the rt program? does it say mini-z asf manager v1.0 on the top of the window or does it say mini-z hg?
www.pnracing.com
gm@pnracing.com
Old 2008.11.17, 03:54 PM   #11
lugnutz
lugnutz's Avatar
mini-hz i dont see asf 1.0,i must be really blind or stuuuuupid
Old 2008.11.17, 03:56 PM   #12
yasuji
yasuji's Avatar
ok the software you got with the adapter is for ad band
www.pnracing.com
gm@pnracing.com
Old 2008.11.17, 04:02 PM   #13
yasuji
yasuji's Avatar
http://www.pnracing.us/MiniZ_ASF_ICS_manager.exe
www.pnracing.com
gm@pnracing.com
Old 2008.11.17, 04:04 PM   #14
lugnutz
lugnutz's Avatar
thanks i'm going to tryit now
Old 2008.11.17, 04:13 PM   #15
lugnutz
lugnutz's Avatar
ok tried it it seemed to work but what is v.inertia do and how do you know that it loaded or programmed the car because i hit program i didn't see any lights flash or anything else happen but when i hit read it read what i programed it to so did it work
FS: RTR Kyosho 1/10th rally car, Airtronics MXA ChattavegasSE Mini-Z Marketplace 9 2008.05.29 10:33 PM
FS:MR02 AD Car + Parts CedMan Mini-Z Marketplace 13 2007.08.06 07:44 PM
'Neutral car' and newbie learning Aurora Mini-Z AWD MA-010, MA-015 5 2007.02.18 07:54 PM
Motor only runs when Car is off! denvajim Mini-Z Racer MR-02 6 2005.03.07 02:10 PM
yokomo 1/27rc car!!!! boroEF Parts and Hop-ups 14 2003.02.04 04:09 PM
