Go Back   Mini-ZRacer.com Forums > General Discussion > New Products
Old 2014.03.20, 07:25 PM   #1
PNracing
Send a message via AIM to PNracing Send a message via Yahoo to PNracing Send a message via Skype™ to PNracing
PN New MA020 7075 Alm. LONG Universal Swing Shaft (2pcs)
LONG Universal Swing for Mini-Z AWD MA020
7075 material with hard coasting
Adjustable 0.5mm Offset wheel spacer, spacer put inside of the shaft, will be +0.5mm offset, spacer put outside will be 0 offset.
2 x Universal Swing
2 x 0.5mm Spacer
http://www.pnracing.com
http://PNWC.pnracing com
DownloadPNICS ICS Android Apps for ICS Setting
PNracing is offline   Reply With Quote
Old 2014.03.20, 09:49 PM   #2
lfisminiz
lfisminiz's Avatar
Tried out a test version of these. A must have for the 020 AWD. The plastic Kyosho ones wont hold up.
Weird goop on Kyosho Hard Universal Swing Shaft angel7692 Mini-Z AWD MA-010, MA-015 0 2012.03.09 10:00 PM
Bind-free aftermarket drive shaft andreophile Mini-Z AWD MA-010, MA-015 16 2008.12.07 01:41 PM
Alm. Universal Swing Shaft ub0211042 Mini-Z AWD MA-010, MA-015 6 2008.04.22 08:22 AM
Pro II AWD Light Weight Universal Swing Shaft. Ton Parts and Hop-ups 0 2008.01.13 08:22 AM
PN Racing AWD light weight Universal Swing Shaft Ton PN Racing 6 2007.10.11 04:38 PM
