Old 2010.03.15, 02:42 AM   #1
syafiq
moe-otaku
syafiq's Avatar
does locking the rear diff can make you drift?
i am beginner is this type of hobby but i am drift fan. the car that i buy doesn't drift very well. the drift has lack of angle when making a long drift. my friend suggest that i should lock the rear diff by using spool diff or solid axle diff rear. so is it locking the rear diff can make you drift?
please don't suggest me other modifications because i already know about that. just tell the modification for the rear diff only.
syafiq is offline   Reply With Quote
Old 2010.03.15, 03:36 AM   #2
TheSloth
Originally Posted by syafiq View Post
...my friend suggest that i should lock the rear diff by using spool diff or solid axle diff rear. so is it locking the rear diff can make you drift?
Do you have an AWD? From your description, it appears you don't.
It looks like RWD cars are very difficult to drift. In any case, toe-in (related to stability and steering response), camber (related to tire grip) and tire type play a more important role in drifting. The answer lies in experimentation for your car and track characteristics. I've found the stock set-up very good for my driving style and track conditions. But I have and AWD car.
TheSloth is offline   Reply With Quote
Old 2010.03.15, 09:07 AM   #3
syafiq
moe-otaku
syafiq's Avatar
i m using AWD MA-010
only AWD can drift in RC car
Old 2010.03.15, 10:36 AM   #4
Action B
The Galliant Dude
You can just glue together a gear differential or even stick a peice of paper or hobby putty into the gears to stop it from moving so it would be reversible. That will lock your rear differential and make it easier to drift. I can't tell you if it will give you the results you want in particular
Action B is offline   Reply With Quote
M.H.S. Racing Discussion HobbyShopOwner Mini Z Racing, Maj's Hobby Shop, Saddle Brook NJ 9983 2016.07.02 01:25 AM
Ball diff changes... HaCo Mini-Z Racer MR-02 4 2007.07.15 03:26 PM
Squat Wide +7mm Diff Shaft DAMZer Parts and Hop-ups 2 2002.07.08 11:33 PM
Locked rear diff MaukaRunner Mini-Z Science 2 2002.06.25 02:09 AM
HELLLP!! rc/rm rear diff ATMOS Parts and Hop-ups 1 2002.03.08 02:35 PM
