Old 2018.08.17, 10:35 PM   #16
mugler
Yes in our case I was thinking of keeping the disk choices to kyosho only to a) keep close to as box stock nature of the class & b) limit the choices as much as possible again staying as close as possible to the box stock theme. (spec by default kinda thing)
Tires, t-plate, bearing, springs, lubes & fluids are open to any brand though. Speaking of lube some 300to500-ish CST lube under the MM2 damper disk (94mm) made my car handle noticeably better.
Also i have feeling FWD in box stock format with only tires and right gearing can keep up with RWDs and they all should be run together...I'll be testing that idea in upcoming months.
Old 2018.08.18, 09:52 PM   #17
I think layout design will have a lot to play in fwd performance relative to rwd. Gearing will play a major role as well. I think fwd could work better for those 90mm bodies that rwd needs to use an rm config
MR03 sports series motor selection flashdaniels Mini-Z Racer MR-03, MR-03 VE, Sports Series, EVO 21 2015.11.12 01:04 PM
MR-03 Sports Series Board Swap byebye Mini-Z Racer MR-03, MR-03 VE, Sports Series, EVO 6 2014.07.29 11:01 AM
Kyosho Mini-Z 2nd Generation Book marc Miscellaneous Discussion 32 2012.12.23 02:47 AM
March 26, 2011 - Reflex Racing Series Mike Keely The Track, Gaithersburg MD 13 2011.03.27 08:24 PM
MC3/ Reflex Racing Points Series info Sinister_Y MC3, Toronto, ON, Canada 0 2011.01.26 09:03 PM
