Old 2010.10.30, 01:47 AM   #1
ub0211042
ub0211042's Avatar
KO Japan replied and confirming the hand unit is causing the problem, new unit will be sent to me. 3 out of 8, thats a scary number . hope no one will experience this again.
Mini-Z AWD 2.4Ghz 94mm
Mini-Z AWD DWS PN A-Arm 2.4Ghz MR03 board 98mm
Mini-Z MR-02 2.4Ghz
Mini-Z MR-03
FX-101 Dnano 360 Modena
ub0211042 is offline   Reply With Quote
Old 2012.01.17, 04:30 PM   #2
oXYnary
New KO Radio - KO Propo EX-1 K.I.Y.
http://www.redrc.net/2012/01/ko-prop...y-transmitter/
My questions are does it have USB/Computer capabilities and most important for here. Can it be set to run on ASF or FHSS per model since it has no module.
oXYnary is offline   Reply With Quote
Old 2012.01.17, 04:50 PM   #3
GIHOSU
Unregistered Abuser
GIHOSU's Avatar
I just saw the release, very interesting to say the least. There certainly will continue to be programming capabilities. I wonder about Mini-Z support...
EMURacing - FAST by FAQISH - REFLEXRACING - Mantis Worx - DG Designs - GSR
CRUIZIN with RCs - Waldwick, NJ
GIHOSU is offline   Reply With Quote
Old 2012.01.17, 04:53 PM   #4
twinkie
those look awesome... i would pimp one with a pink handle... its different, i like it.
twinkie is offline   Reply With Quote
Old 2012.01.17, 05:04 PM   #5
That radio looks sick. If it works with Mini-Z, this may be my next radio...
Old 2012.01.17, 05:49 PM   #6
KO PROPO Staff
It will have PC connection, but what the software does has not been released yet. This is only for the current FHSS system and not for Mini-Z.
I don't know what the plans are for Mini-Z yet. Might be a separate main unit that you change out.
KO PROPO Staff is offline   Reply With Quote
Old 2012.01.17, 05:58 PM   #7
looks interesting. it would be nice if it were mini-z compatible via module.
how does one change out components? are their diagrams yet?
Old 2012.01.17, 06:16 PM   #8
oXYnary
Thumbs up for the PC connection.
I hope the ASF can be dealt with with a firmware update, I know my Nomadio was able to take different 2.4 standards *until Horizon tried to sue them.
Shouldn't be any reason to have to use different hardware especially since KO would be for both for ASF and FHSS. Should be just reprogramming the radio chipset to broadcast/receive differently.
Do you know if the Moto MiniZ FHSS will work though?
Old 2012.01.17, 08:36 PM   #9
josyskunk
I was wondering when it will be released?
josyskunk is offline   Reply With Quote
Old 2012.01.17, 10:15 PM   #10
color01
color01's Avatar
Bleeeegh 4AAA. Unless KO has some clever tricks in the electronics department (I hope so!) this radio runs the risk of getting drowned out by the 11.1V and sometimes even 14.4V radios at the track!
Brian Ma
Greyscale RC
PN Racing | My TinyRC Blog
Old 2012.01.17, 11:11 PM   #11
TheSteve
VE7FM
The voltage is irrelevant, any/all 2.4ghz radios run the transmitters at 3 or 3.3 volts no matter the input voltage.
Anyway, I'll stick with Futaba...
TheSteve is offline   Reply With Quote
Old 2012.01.18, 02:58 AM   #12
color01
color01's Avatar
While I've been told this as well, the last KT-18 I've owned had a significantly stronger signal with a 7.2V Li-ion replacing the stock 4.8V setup. My Eurus gets drowned out much less now after I replaced the 9.6V pack with an 11.1V LiPo. I can't explain that, so I'm going on my empirical data.
Brian Ma
Greyscale RC
Old 2012.01.18, 06:38 AM   #13
BlackBerry
I'm I the only one that finds this thing hideously ugly? Maybe seeing one with black grips will change my mind. On second thought, no it won't.
BlackBerry is offline   Reply With Quote
Old 2012.01.18, 09:43 AM   #14
J-Milz
J-Milz's Avatar
Looks like some Star Wars she-ite....Its uglyness make it even more attractive....if that's possible. Im also concerned about the compatability with other scales, since there is no removable modules. I run spektrum stuff in my larger scales, and was wondering if that will all become junk if I was to convert.
PAYNE RACING
Action RC ALUMNI
J-Milz is online now   Reply With Quote
Old 2012.01.18, 12:49 PM   #15
Gonzo007
Nope you are not the only one. I will stick with my 4pk.
Colin
Gonzo007 is offline   Reply With Quote
***For Sale: *KO Propo Radio * KO ProPo Mini Z Module *** nugget Mini-Z Marketplace 4 2010.07.29 09:16 AM
ko propo ex-1 mars radio fs bobbyz Mini-Z Marketplace 2 2010.07.19 02:58 AM
FS: Ko Propo EX-I UR radio with upgrades and LIPO davskee Mini-Z Marketplace 3 2009.11.02 05:37 PM
FS: KO Propo EX1-UR with Kyosho radio case reechaard Mini-Z Marketplace 5 2008.11.16 03:11 AM
FS: Ko Propo Mars R radio for Mini-Z - $150 pchan0 Miscellaneous Discussion 0 2003.08.25 05:52 PM
