Old 2006.01.02, 12:31 PM   #1
Draconious
Draconious's Avatar
AutoCad File for RCP Track
This is my old 3D RCP track file I made in auto cad. I finaly got around to cleaning it up and adding in the pins.
I have it setup so the tiles are centered on the autocad snap... so just copy a tile and move it with the SNAP on, and it will auto line up... or use the circle nodes I put on each tile to line them up via center and quadrant points.
Once you get the tiles oriented the way you want, u can use autocad to render it, and it will look like the sample image.
http://quantumrc.com/Files/RCP-TrackBuilder_June07.zip
Old 2006.01.02, 04:18 PM   #2
briankstan
SLMZ / HFAY
briankstan's Avatar
great job on the drawings. I did a similar thing with mine. I made each tile with the correct dims. I change them a little so I could easily snap them from corner to corner with out having to worry about the the way they actually attach. Basicly they are the same size just with out the connectors. it works really great for making my layouts. I do them in 2D just to keep it simple and easy to see.
Old 2006.01.02, 04:28 PM   #3
Draconious
Draconious's Avatar
Mine work in 2D as well... just unshade and have at it in the plan view lol
Old 2006.02.14, 12:44 PM   #4
Draconious
Draconious's Avatar
Updated the file to:
fix a slight error in the orientation of the tiles
add in my version of the RCP 45 tiles
add in my version of the RCP 50cm to 30cm convertion tiles
File available at same url:
Also updated images, showing new tiles, and 2D apearance.
Old 2007.11.09, 02:00 PM   #5
can you fix your site address? the link does not work anymore
Old 2007.11.09, 02:18 PM   #6
Draconious
Draconious's Avatar
The link above was just messed up it added ... when it should not have... was same amount of characters...
Anyway Arch if you DL this and look at it again... look at all the tiles, if you have time, and see if any of them have the center cyan node off center... i want to make sure this is the version that I fixed that has been online all this time... if not I need to upload a fixed version.
Old 2007.11.09, 02:33 PM   #7
looks like the right ones thanks for fixing that, came thru in a pinch
Old 2007.11.09, 03:06 PM   #8
Draconious
Draconious's Avatar
I guess I never did the propper wide-45 degree Set did I? only my own conept... oh well maybe one day I will get to it.
Old 2007.11.10, 05:52 PM   #9
drac,
is it possible to get stl exports of the cad files?
Old 2007.11.11, 03:27 AM   #10
Draconious
Draconious's Avatar
Why STL? that is the most crude form of cad there is... it will lose all the good data.
Old 2007.11.11, 06:55 AM   #11
other software used for machining can import from stl. i tried making the conversions but it doesn't seem to want to work with my version of autocad.
Old 2007.11.11, 01:04 PM   #12
Draconious
Draconious's Avatar
STL is not nessessarily modifiable once its made... its very crude... and its not really meant for machineing. It can be used in a Rapid prototype machine though. Machineing requires CAM files.. from whatever software you use to do the tool paths. Cimitron MasterCAM etc... (stuff I am doing at school). So it depends what your going to do with it... I cannot just save as .STL it wont work that way.. you would have to explode each individual, block, then have each mesh or track wall piece etc... in a seperate file.
Old 2007.11.11, 08:20 PM   #13
Draconious
Draconious's Avatar
Just opened the file to look at it again... the one ONLINE.. not the one on my HD... and the one online does not have all of the track pieces that I have made... I guess I will have to upload yet another version soon.
Old 2012.04.09, 07:50 AM   #14
can anyone confirm the precise distance to center-line of rail pins? my cad files measures 9 5/16" but that seems very close together.
RCP-Tracks FAQ's RCPMini-z Tracks and GTGs 149 2011.11.28 08:56 AM
Track Change pick High Speed Hobbies, NC 38 2010.04.22 06:31 PM
Miniz experience in Tokyo, Japan Aurora Miscellaneous Discussion 17 2008.07.10 04:45 AM
Which Track would you recommend for me mithuth Tracks and GTGs 21 2005.07.15 07:51 PM
RCP Track Review briankstan RCP Support Forum 5 2005.06.07 06:55 PM
