Go Back   Mini-ZRacer.com Forums > Manufacturers > Flip Side
Old 2009.05.05, 12:57 PM   #1
pinwc4
pinwc4's Avatar
Flip Side hardware support requests
Currently the Flip Side Racing software is limited in its hardware support. Here is a list what is supported so far and what has been requested
Supported Lap Counting Hardware
  • Core Speedway
  • Kyosho IC Lap Counter Home Edition
  • I-Lap
  • Robotronic
  • GKA9805 (Global KeyAccess UHF EPC G2 RFID reader, not Core/Kyosho compatible)
  • WanhaRacing (custom hardware not for sale, yet)
In Progress Lap Counting Hardware
  • Giro-Z
Other Supported Hardware
Requested Hardware Support
  • USB Bit Whacker (This board could be used for a Laser Lap Counter, need the hardware still before proceeding)
Hardware that will not work
In order to determine if I can add support for additional hardware I need someone who has access to the hardware to work with so that I can get various information information from them. Or if possible it would be quicker for me if I could get access to the hardware for a week.
If you have access to the hardware that you would like supported the first step I need done is to capture some of the raw information that lap counter produces. From Windows the way you do this is as follows:
  1. Download Portmon from http://technet.microsoft.com/en-us/s.../bb896644.aspx
  2. While the lap counter software is NOT RUNNING start the Portman application
  3. In Portmon go to the Computer Menu and select Connect Local
  4. Under the Capture Menu go to Ports and then Select all the COM ports available
  5. Under the Options Menu make sure the Show Time, Show Hex and Clock Time options are selected
  6. Now run the lap counting application and run a short 1 minute race preferably with 2 cars though if it is just 1 person switching between cars that is fine
  7. After the race is complete close the application
  8. Go to the Portmon applcation and go to the File Menu and save the log file
  9. Send me the log file along with the transponder ID's of the cars in the race
pinwc4 is offline   Reply With Quote
Old 2009.05.07, 07:09 AM   #2
mferrini
I can help with the AMB20
mferrini is offline   Reply With Quote
Old 2009.05.07, 12:12 PM   #3
pinwc4
pinwc4's Avatar
Did you try the CDog4w hardware type and find it does not work with AMB20? If so go ahead and run the Portmon program like I mention in my first post and send me the log data. It should not take much tweaking to make it work with AMB20 if it does not already and that log will give me the details of how it communicates.
Thanks
Old 2009.05.13, 11:46 AM   #4
kalou60
hi
pinwc4 how to listen serial port with portmon, if i use a converter serial->usb, because i have try but nothing there are a tips ?
kalou60 is offline   Reply With Quote
Old 2009.05.14, 05:57 PM   #5
pinwc4
pinwc4's Avatar
Originally Posted by kalou60 View Post
hi
The steps in my first post should have worked, I just tested again. Make sure you select Connect Local in the Computer menu and under the Capture menu go to Ports and select any COM ports in their.
It does not matter if it is a serial->usb adapter Portmon should pick it up.
Old 2009.11.06, 07:02 AM   #6
pixelforce
ic tag lap timer
Hi there,
I have access to IC Tag Lap timer Hardware ... if It helps contact me.
Best regards
pixelforce is offline   Reply With Quote
Old 2009.11.06, 02:13 PM   #7
pinwc4
pinwc4's Avatar
Originally Posted by pixelforce View Post
Hi there,
Best regards
Thanks for the offer of help. I have the Kyosh IC lap counter also and am working on making it compatible. When I release a version of the software that fully supports it I will welcome feedback from people that also have this hardware.
Old 2010.01.04, 11:15 AM   #8
LED
Would you be interested in the robitronic lapcounter ?
We have it ordered. Hoping to have it in the next couple of weeks.
LED is offline   Reply With Quote
Old 2010.01.04, 03:21 PM   #9
pinwc4
pinwc4's Avatar
I would be interested, yes. I know very little about that particular hardware. If it shows up as a COM device to the computer then it may be possible to work with it.
Old 2010.01.04, 04:31 PM   #10
LED
I think it isnt any different then other lapcounters out there. Only thing I know for sure is that the transponders have a fixed ID.
I'll get back to you when we have it and have done some experimenting of our own with the com reading.
Old 2010.02.22, 02:18 PM   #11
LED
Hi
I send you a PM
Old 2010.02.22, 04:12 PM   #12
pinwc4
pinwc4's Avatar
Hi
I send you a PM
Thanks, I emailed you back. I will see what I can figure out with the Robotronic system after you send those logs you collected.
Thanks for the help.
Old 2010.02.23, 09:57 AM   #13
LED
I didnt get anything ?
Old 2010.02.23, 10:47 AM   #14
pinwc4
pinwc4's Avatar
Yeah apparently I sent the email to mini-z. I sent you a PM with my email address.
Old 2011.01.05, 12:26 PM   #15
doug01n
doug01n's Avatar
Send a message via MSN to doug01n
I can help with the trackmate information... I'll try to make the tutorial in the first post tomorrow at our track!
doug01n is offline   Reply With Quote
Flip Side Racing Software feature requests and bugs, original thread pinwc4 Flip Side 409 2010.02.06 03:36 PM
Flip Side Racing Software Info pinwc4 Flip Side 0 2009.05.01 09:29 PM
on my mini z the tires on the right side are looser than the left left side. mini Z modifier Beginner Questions 4 2002.08.02 09:42 AM
