2007.10.16, 05:45 PM
2.4Ghz MR-02LM LeMans Series
New Perfex Transmitter, KT-18 ASF
•The new KT-18 TX unit will allow 40 Mini-Zs to race at the same time.
•Will automatically search for an open Frequency, NO Xtals needed!
•Radio response speed increased 33%, compared to the KT-5
•Only one radio required to control other 2.4ghz equipped Mini-Zs
•Steering angle and throttle angles can be adjusted
•Digital trim adjustments
•Blue LED lights indicate Power, Bind Mode, and Training mode
•Only 4 AAA Batteries required for TX operation
•Expansion slot for add on features. (available in future)
February 2008 Arrival
82001B TX only
MSRP NYA
Release Date: Jan/Feb
MR02LM Series with 2.4Ghz System ARR
•Fully factory assembled chassis with high capacity FET
•NEW 2.4Ghz radio system
•Pre painted bodies
•Four sizes of pinion gears
•Pinion gear tool
•Spacers for front suspension adjustment
TECHNICAL DATA
Scale: 1/27.6
Length: 180mm
Width: 78mm
Height: 39mm
Wheelbase: 102mm
Weight: 130g
Gear Ratios: 7.3, 6.3, 5.5, 4.9:1
Tire Diameter: (F)23.5mm (R)27mm
Tire Width: (F)9mm (R)12mm
Transmitter: KT-18 (Sold Separately)
* NEW FEATURES *
•New motor case and friction dampener as
standard equipment.
•Motor now located 5.5mm lower and
2.5mm toward the center, compared to the MM motor case.
•Equipped with I.C.S Port
•Transmitter and receiver response time has increased 33%
•2.4Ghz Technology
30441KR-B Porsche 962 No.10
MSRP NYA
2007.10.16, 06:16 PM
Q1 : front wheel is small than Rear or just the picture ?
Q2 : upper connector is for ICS. or to binding process ?
Q3 : Rear Axle differential is larger than MR02 ? Does it's the same large than F1 ?
Q4 : What type of fets comes with this chasis ? 3010? others ?
Regards
2007.10.16, 06:19 PM
Regards
all information I have, is posted above. When I can get my eyes on more information, I will get it passed along to the Z community asap. So please be patient if your questions are not answered right away.
ICS will be used for dialing the speed control and steering servo.
2007.10.16, 07:17 PM
Mini-Z Electrician
Very cool Tim, thanks for the pics. Can't wait for more info.
2007.10.16, 08:44 PM
Go for it. I don't have many answers just yet. But Japan is hating me ...lol...So i am sure i will have answers soon
2007.10.16, 09:06 PM
THATS HOW I ROLL
Tim, do U know if, just to say if I had a spectrum module for a helios do U know if that would work with the new 2.4Ghz mini z?
2007.10.16, 10:00 PM
that Orange car is fast..
Or if the new mini-z 2.4 module for the new Ko Propo radio will work in the helios ex-10. The photo's show a new radio that looks like it has the mars foot print.
Tell KoPropo guys are asking if they should hold off buying a ex-10 or not.
2007.10.17, 12:37 AM
Regards
trying to answer....
from the info given above
a1:
and the pic... the front wheel/rim does look smaller (measured it with a ruler hahaha) although i may be wrong...
usually rear and front rims/tires are of different sizes in the real le mans cars too...
btw... tire/rim sizes (from kyosho mini-z vol.2 optional parts list)
diameter of racing rims is 20mm while the tire diameter is 25mm
diameter of classic rims is 17mm while the tire diameter is also 25mm
classic rims are the type of rims you can find on the shelby cobra427,lamborghini jota, ferrari 512bb and the porsche 934...
a3:
from the info given above Width: 78mm... i don't know if it's the body width or the track width... so assuming it's the track width... i am taking an educated guess (again i may be wrong) that the rear diff may be a bit wider than the mr02... not sure if it is as long as the f1 diff though...
also the kyosho mini-z vol.2 optional parts list states that the widest track width is on the lamborghini jota at 76mm which has an offset of 3mm per rim (the parts list didn't list the track width of the enzo so i wonder...)
anyway i'm thinking having a rear offset of 4mm (on a mr02 diff will give us a track width of 78) might be too much and make the rim pretty susceptible or prone to breaking... besides from the picture in another thread, it visually looks wider...
i wonder if professor tim can confirm my answers, don't worry, i'm not in a hurry...
2007.10.17, 12:39 AM
All KO Modules are pretty much interchangeable now. I wouldn't see why a new one wouldn't work with the old transmitters. I use an AD band module for Helios on my Mars R. THe Spektrum module is also for use with Mars/Helios as per Horizon hobby.
Either way, I'm finally getting a new Transmitter (EX1 Ur) hehehe! I hated the Helios case! Just too big for my hands.
2007.10.17, 01:37 AM
awww man that's cool....
January eh? Nice...
2007.10.17, 03:46 AM
hmm... selling the car alone with the "Transmitter: KT-18 (Sold Separately)" will probably be a really good idea... that way one can either choose to purchase the kt-18 or a module that will hopefully come out soon as well...
i'm thingking if you can swap out the old mr01/02 board with the newer 2.4ghz board... and how much would that cost?
but on the other hand it might be cheaper to get a 2.4ghz chassis kit if and when kyosho does have it in the offering....
2007.10.17, 07:32 AM
Let me be the first to nominate this body for production with this chassis!
2007.10.17, 07:43 AM
that body would be a good start for the japanies market, as it is a japanies team.
Mini-Car Club of Canada (MC3) Member
