Atomic RC and HKS Hobby present Atomic USA Mini-z World Cup 2009. See tentative rules below. Locations will be announced shortly.
Rules/classes....etc are subject to periodic revisions.
Class
a. *2 Wheel Drive Stock (Atomic World Cup Series) /
b. *4 Wheel Drive Stock (Atomic World Cup Series) /
c. 2 Wheel Drive Open Stock /
d. 2WD or 4WD Modified Open Class /
e. Formula One Stock (Open) /
* A main winner in 2WD & 4WD Stock Class ( Atomic World Cup Series) will qualify for the grand prize drawing of round trip air ticket plus hotel (3 lucky winners) for ‘2009 Atomic World Cup Final’ in Macau.
Rules & Regulations
a. 2WD Stock
Battery : AAA NIMH only
Body : Kyosho only
Motor : Stock (hand out # MO-USA)
Minimum Weight : 180g
Min/Mix Wheel Base : 86-98mm
Tires : Mini-Z type Touring Rubber (any brand)
Remarks : Atomic hop-ups or Kyosho parts/hop-ups only
b. AWD Stock
Body : Kyosho only
Minimum Weight : 190g
Min/Mix Wheel Base : 90-98mm
c. 2WD Open Stock
Body : Kyosho only
Remarks : Any hop-ups
d.2WD/AWD Modified Open (Subject to final revision)
Body : Atomic (AR-125, AR-210, AWD204) & Kyosho Autoscale
Motor : Any Atomic motor
Minimum Weight : Open
Min/Mix Wheel Base : 86 -98mm
c. Formula One
Body : Kyosho F1 autoscale
Minimum Weight : TBD
Min/Mix Wheel Base : stock WB
Tires : Kyosho Mini-Z F1 or Atomic F1 Wheels/Tires only.
Remarks:
- Each class has 3 qualify runs of 6 minutes and a final run of 14 minutes. (Subject to revision)
- All classes (except 2WD/AWD Modified Open) will run on ‘ATOMIC’ controlled hand out motor only. Further modification is NOT ALLOWED. Additional motor may be available from race director at racer’s expenses.
- 2WD/AWD Modified Open Class accepts any motor from any manufacturer. No hand out motor will be provided.
- Formula-one Class will run on ‘Kyosho Auto Scale’ formula-one body only.
- ESC & Receiver limited to Atomic or Kyosho PCB Board with the exception of ‘2WD/AWD Modified Class
-No traction compound or wet tires on track
Reason: Revision 1.0 Dated 1/21/09
Is the chassis restricted to Kyosho chassis, or can we use any chassis that is the same scale? (MRCG, P28, Pro-Z, Iwaver, home made) I see that the electronics are limited to Kyosho for the stock classes, but are the chassis limited as well? Can you use the Kyosho electronics on a different chassis?
I just want to get this cleared up before I try to decide what classes I would run.
Thank you,
Eugene
d.2WD or 4WD Modified Open
Battery : AAA only
Remarks : Upgrade part open to any brand
- 2WD or 4WD Modified Open Class will open for any brush motor from any manufacturer. No hand out motor will be provided.
- 2WD or 4WD Modified Open Class may run on both touring car or pan car body from any manufacturer. Home made or prototype car body is welcome but subject to final approval by on-site race director. Race director has the right to reject any disturbing design or any car body that may cause possible interference to other driver or the race.
Hello,
I am Nik,thanks for updating regarding the USA Mini-z World Cup 2009 and glad to join the events.Just give the Registration date that i can participate in the race.
