Old 2004.12.30, 09:33 PM   #1
festus105
Question Electronics question
Anyone know what the maxium voltage a Kyosho mini-z receiver can tolerate? Somone told me that the mini uses volts - 4 AAA batteries equals 6 volts. Can it handle 9 volts. I want to use the electronics for another application but I don't want to fry the board. Hope someone can help. Thanks
Ken C.
festus105 is offline   Reply With Quote
Old 2004.12.31, 08:27 AM   #2
Ninja
Mechanic
Ninja's Avatar
i have seen them, and the iWaver boards, handle up to 10 volts
Real Racers Do It Sideways.
Old 2004.12.31, 08:42 AM   #3
ExtraPickles
Bringing up the rear...
ExtraPickles's Avatar
Maybe not all of them (iWaver)? I thought I read somewhere about Lithium batteries frying the single steering FET?
-pickles
ExtraPickles is offline   Reply With Quote
Old 2004.12.31, 09:05 AM   #4
Ninja
Mechanic
Ninja's Avatar
he doesnt need steering, he is using it in a small scale train
Old 2004.12.31, 09:40 AM   #5
festus105
Thanks...that's exactly what I needed to know. Now is the Iwaver electronics as good as Kyosho's?
Ken
Old 2004.12.31, 09:45 AM   #6
Ninja
Mechanic
Ninja's Avatar
yes, the only thing lower quality would be the steering, which you arent going to be using
Old 2004.12.31, 09:49 AM   #7
festus105
Thanks...you've been a big help....I'll probably just get an Iwaver readyset becaues I need the transmitter / throttle as well. Is there any difference in Iwaver 01, 02, 04 or MR2 sets? Do all have reverse and proportional throttle response and the same board?
Old 2004.12.31, 09:50 AM   #8
Ninja
Mechanic
Ninja's Avatar
all the new iWavers use the same board, and all fully proportional
Old 2004.12.31, 09:53 AM   #9
festus105
Sorry for all the questions...what would be an "new" Iwaver set? I see all kinds on Ebay and online. I just want to know what I'm looking for.
Ken
Old 2004.12.31, 09:56 AM   #10
Ninja
Mechanic
Ninja's Avatar
i mean the newer production, not newer models, most likely all of the ones you find on ebay are newer iWavers
Old 2004.12.31, 09:59 AM   #11
festus105
Thanks...you've been a great help.
Old 2004.12.31, 03:25 PM   #12
Draconious
Draconious's Avatar
by same board they mean same board amongst all the new i wavers... not old i wavers.. and its NOT 100% the same as the kyosho.. just "similar"...
Old 2005.01.25, 05:40 PM   #13
chilau
Max voltage of F1 mini z board
I've just complete a 7.4 volt lipo conversion to my car and it seems to be holding up ok.
I've installed 2x2 4562 fets with a heatsink and am running a 37 turn motor and nothing is getting to hot.
I think about 8 volts is the maximum voltage that can be run on this board as the diodes underneath the board are rated at 6 volts.
Any higher voltage would require changing all of the diodes on the bottom of the board.
Converting to Lipo's gives an amazing increase in performance due to the lighter weight, higher voltage and ability to deliver higher currents.
chilau is offline   Reply With Quote
Old 2005.01.26, 01:22 PM   #14
Hills
Send a message via AIM to Hills
I believe the mr-02/monster pcb board will take up to 10 volts
Hills
A lithium battery set up will not fry the fets any faster than none lithium, the fets are current limited not voltage limited. (well.. I am sure they are voltage limited but there tolerance range is at least 10 volts), just checked and the fet is max 20 volts.
Lithium Ion SE 2x2fet Monster and GF single feted Monster
Contact Me: ashills@gmail.com
My stuff for SALE
Hills is offline   Reply With Quote
iWaver electronics with an MR02 servo... Programmers Mini-Z Science 4 2007.07.08 03:36 PM
Could anyone print purple question marks for me? Spoon Custom Bodies 3 2006.10.16 10:50 PM
Selling some electronics... kehern15 Miscellaneous Discussion 3 2006.01.09 02:21 PM
Newbie Question to Motor Winding. Phenochilus Motor Tech 5 2004.10.20 08:54 PM
MR-02 electronics! jeffrey Parts and Hop-ups 2 2003.07.30 02:14 AM
