Old 2018.07.25, 07:52 AM   #1
New Kyosho Mini-Z Products 2018
Just noticed there are a few new Kyosho products forthcoming...
VE setup cable 2.0 (for mini buggy MB010VE 2.0) 82082
No: 82082
FRP Rear Suspension Plate Set (for 0.6 / MR03 RM / HM) MZW 438
No: MZW 438
Release month: July 2018
Three kinds of soft, medium, hard, hard type with 0.6 mm thick where the conventional part (MZW 410) is 0.5 mm thick. With type for identification.
FRP rear suspension plate set (for 0.5 / MR03 MM / LM / MM 2) MZW 437
No: MZW 437
Three types of soft, medium, hard, soft type with thickness 0.5 mm thick where the conventional part (MZW 409) is 0.6 mm thick. With type for identification.
Ball differential set Ⅱ (MR03 MM / MMⅡ / RM / HM) MZW 436
No: MZW 436
Compared to conventional ball differentials, the weight of aluminum parts on the spur gear side is reduced, and the hose side can be added with a screwdriver considering the balance.
Ball differential set Ⅱ (MR 03 LM) MZW 308
No: MZW 308
Compared to conventional ball differentials, the weight of aluminum parts on the spur gear side is reduced, and the hose side can be added with a screwdriver considering the balance. For LM mount
MJ aluminum motor mount (MM II) MZW 434
No: MZW 434
Motor mount for MM 2 with high precision aluminum scraping.
Made in Japan pursuing accuracy, beautiful meat punching and tightly made make you feel the craftsmanship. By optimizing the balance of the car body by replacing it with a moderately heavy aluminum considering the weight distribution of the right and left from the normal plastic, contributing to the improvement of the traction performance, it also has the heat sink effect unique to aluminum material. By using the sliding backlash adjustment function to the utmost, proper backlash adjustment is possible regardless of the pinion to be used.
Friction damper set (carbon / MM II) MZW 435
No: MZW 435
Carbon friction damper for MM 2 designed for use together with MJ aluminum motor mount. It corresponds also to a normal plastic mount. * When using it for normal mounting, normal is used for upper and lower plates. Or it is necessary to enlarge hole of carbon plate.
In my opinion, Kyosho should have numbered the H/T plates, always. Nothing worse than openign a box of parts trying to figure out by comparison which is which.
Old 2018.07.27, 12:48 PM   #2
Any pics for reference?
Old 2018.07.27, 02:23 PM   #3
you can find photos on their website.
Old 2018.07.28, 05:59 AM   #4
The new differential and MJ mount look interesting. From a quick search, it will be expensive...
nice to see that they are finally labeling the t-plates. With two thicknesses, and 3 widths, we now have more options to tune without needing to change a top shock. Good for disc damper use.
The diff looks like there is more machining to keep it light. I wonder if they will use D rings, or standard like they have always used. The standard kyosho rings are some of the best that are available in terms of flatness and hardness, however can be a pain due thi slippage on the holders.
Thanks for the update arch, see you in a few hours. I've been wrenching on some cars all night to prepare.
Old 2018.08.30, 07:27 AM   #5
October release
RENAULT MEGANE R.S. Serius Yellow
No : 32421Y
RENAULT MEGANE R.S. Tonic Orange
No : 32421OR
On Sale From : October 2018
■Length 161.5mm
■Width 70.0mm
■Height 54.0mm
■Wheelbase 98.0mm (LL)
■Chassis FWD(MA-03F)
■Front Wheel Offset Narrow +1.5mm (for AWD)
■Rear Wheel Offset Narrow +1.5mm (for AWD)
■R/C System Syncro KT-531P
Old 2018.08.30, 07:37 AM   #6
September release
First MINI - Z Initial D Toyota Sprinter Trueno AE86
No: 66601
First MINI - Z Initial D Mazda Savanna RX - 7 FC
No: 66602
First MINI - Z Initial D Mazda RX - 7 FD
No: 66603
Release month: September 11, 2018
Old 2018.09.12, 07:13 AM   #7
New bodies... honda civic type r
File Type: jpg Screenshot_20180912-190155_Facebook.jpg (371.4 KB, 103 views)
Old 2018.09.12, 08:03 AM   #8
The Civic is controversial with regard to style but this may be the one that gets me to pick up FWD over the Mazda or Prius. I'm not a fan of the Civic either but of the options, it is the least objectionable.
Old 2018.09.14, 06:37 PM   #9
mugler
This was the link this pic was on along with another grey/orange/black colorschem P1 but right now that link not working, not sure why. Suaber re-release was also on that link.
http://rc.kyosho.com/ja/ths2018/
Old 2018.09.14, 07:46 PM   #10
McLaren P1 GTR Yellow / Green
No: 32324 YG
No: MZP 235 YG Autoscale
No: MZN 190 Unpainted
McLaren P1 GTR Silver / Orange
No: 32324 SO
No: MZP 235 SO Autoscale
Re-release
Mercedes Gruppe-C-Rennsportwagen C 9, Nr. 63, LM 1989
No: 32327S
No: MZP343S Autoscale
No: MZN 193 Unpainted
Audi R8 LMS 2016 "Black / Red"
No: 32323 BKR
No: MZP 234 BKR Autoscale
Renault Megane RS Tonic Orange
No: 32421 OR
No: MZP 441 OR Autoscale
No: MZN 187 Unpainted
Renault Megane RS Sirius Yellow
No: 32421Y
No: MZP441Y Autoscale
Honda Civic Type R Championship White
No: 32424 W
No: MZP 445 W Autoscale
No: MZN 194 Unpainted
Honda Civic Type R Frame Red
No: 32424 R
No: MZP445R Autoscale
Old 2018.09.15, 12:38 AM   #11
More pics
File Type: jpg Screenshot_20180915-010935_Facebook.jpg (121.1 KB, 89 views)
File Type: jpg Screenshot_20180915-011003_Facebook.jpg (126.7 KB, 89 views)
File Type: jpg Screenshot_20180915-011039_Facebook.jpg (135.3 KB, 89 views)
File Type: jpg Screenshot_20180915-161228_Facebook.jpg (128.0 KB, 84 views)
Old 2018.09.15, 02:28 AM   #12
TPDazzle
It is interesting that Kyosho is willing and able to make so many licensed slot car bodies in full racing livery in many of the cars I would like to see in mini z (Corvette C7, BMW GT3, new Ford GT, Audi RS 5 GT3, Mercedes AMG GT3, Ferrari 488 GT3, and a Lambo Huracan GT3, and several new F1). I wish some of those would come our way. I assume either the price structure is either more for rc cars vs slot, or they are convinced they can sell a lot more.
There are a couple racing trucks for those of you that are pursuing that avenue. The new McClarens look interesting, but nothing like their new lineup of slot cat bodies..
Old 2018.09.17, 01:33 PM   #13
MR-03EVO Chassis Set(W-MM/12000KV)
No : 32790
MR-03EVO Chassis Set(N-MM2/5600KV)
No : 32791
MINI-Z EVO Receiver Unit KT531P 432PT
No : 82041
Reciver unit for the MINI-Z EVO chassis.
Supports the KT-531 and KT432PT transmitters.
MINI-Z EVO Receiver Unit KT18 EX6 EX6R
No : 82040
Receiver unit for the MINI-Z EVO chassis.
Supports the KT-18 (ASF only), EX-6 and EX-6R (ASF and MHS) transmitters. Also supports KO Propo's EX-2 and EX-RR (MHS only).
Old 2018.09.17, 01:46 PM   #14
SPEED HOUSE 800 HV AAA Nickel Metal Hydride Battery (4 pcs)
No: 71998
Old 2018.10.23, 02:43 PM   #15
HaCo
02-Racer
HaCo's Avatar
Looking forward to upgrade my FWD chassis with the Megane RS!
shop.tinyrc.com (Corrected): 10% off ALL MB-010 Products, 40% off Mini Inferno Bodies Mrs Mini-Z Newsletters 1 2012.04.20 10:36 AM
shop.tinyrc.com (Corrected): 10% off ALL MB-010 Products, 40% off Mini Inferno Bodies Mrs Mini-Z Mini-ZRacer.com Announcements 0 2012.04.09 01:14 PM
Kyosho mini z overland hummer h2 readyset monkey19 Mini-Z Marketplace 1 2010.08.12 10:32 AM
24 Hours of Le Mans = 24% off AutoScales!!! Mrs Mini-Z Promotions 1 2010.06.12 12:19 PM
FS: Z w/ all Kyosho hopups pchan0 Miscellaneous Discussion 1 2003.06.25 06:50 PM
