Old 2018.05.14, 07:35 PM   #1
akura2
PROFESSOR TRUTH JIMMY ICE
akura2's Avatar
Send a message via Skype™ to akura2
How far can you go with a Sports2?
Same as title... since it is getting hard to find ASF-based Mini-Zs, but Sports and Sports2 are abundant... how far can you take a Sports two with the limitations of the stock board? (although I can get an ASF board from Banggood at a later date if I desired)
I just bought one because I couldnít pass up the price and Iím getting back into Mini-Z... (just got an MA-020ve Pro drift set with the Mazda body and the gyro to build off of... Already changed to the Audi and added rubber tires) I wanted to get a Ďstockí Mini-Z to race in the local stock class... but I also wanted a platform to build from once I see what the local racers are running so I can build to match...
"He who KNOWS he's stupid is actually kinda smart"
akura2 is offline   Reply With Quote
Old 2018.05.14, 08:45 PM   #2
Pn 70t 12/52 pinion... 4.75 ratio.
Old 2018.05.15, 01:24 AM   #3
akura2
akura2's Avatar
I could eventually swap in an ASF board though right? (Either original or Banggood)
Old 2018.05.15, 01:29 AM   #4
Yup, easy swap in... Kyosho really complicated things with the sports. ASF can pretty much handle any 130 motor (with proper gearing)... and sports was a step back to the early AM days. Actually, I think the AM cars had a higher tolerance. I wouldn't buy a sports unless I needed one to participate in a stock class race.
Old 2018.05.17, 04:16 PM   #5
akura2
akura2's Avatar
Thatís the reason I got it... stock class 90mm... but I wanna use my KT-18... so Iím thinking about swapping out... but I may not have to if Iím only going 70t...
Old 2018.05.21, 12:45 AM   #6
I ordered the banggood 2.4ghz board and hope to convert a 27mhz mr015 or mr02. Hope my soldering skills are good enough for the job. Will just have to know which wire goes where.
Old 2018.05.21, 01:00 AM   #7
akura2
akura2's Avatar
Well there are several diagrams and photos to show the way the wires go... and if you have a small tipped soldering iron that gets hot enough... you should be ok...
Old 2018.05.21, 05:40 PM   #8
I have and have raced 3 mini-z Sports. (Two S-2 and One Sports). Contrary to what a lot of people report, I have not had a bit of electrical problems. One of my cars has a hard time getting into reverse sometimes which can be frustrating. I participate in HFAY racing and run the PN 70 T motor in all three cars ( I do abide by the gearing recommendations from the Kenon Website). I don't think the controller is much worse than the KT-18, try it a bit and see what you think. Be careful about what kit you buy or you will have to buy and swap a bunch of parts to get into a 90mm class. Might as well get what you want to drive to begin with and be ready to roll.
That said, I find the sports series extremely frustrating. I recently decided I wanted a nicer radio, but I didn't want to pay a bunch of money for a Flysky or Kyosho 432 just to run the same limited board. I also wanted to run in a modified class and also have access to higher gear ratios if I wanted. I ended up buying 2 DasMikro boards (around $43each on Banggood) and buying a new EX-6r. I love the new radio compared to the KT-19, but it was annoying to have to buy EVERYTHING. I am keeping one stock with the stock radio for a class that I race in occasionally. I am no expert, but the soldering was not bad. Sorting out some kind of jig to hold the wires and/or board when you solder really helps. I used a rubber tipped quick clamp to hold the board, and small alligator clips to hold the wires. Good Luck!
Old 2018.05.21, 06:40 PM   #9
akura2
akura2's Avatar
Well, the reason I want to use my KT-18 is that you can't adjust the throttle trim on the KT-19 and my PN70T has too much drag brake... I'd like to be able to dial the trim for more 'coast'...
Old 2018.05.21, 07:12 PM   #10
I love drag brake... but, with 70t, it can be a bit much. Especially when you cannot adjust throttle trim or expo... I always run a positive curve on slow motors.
Old 2018.05.23, 12:30 AM   #11
akura2
akura2's Avatar
I like drag brake too... but a light drag brake... right now when I let off the throttle the back end of my car just whips around... I DID put another 70t motor in it today and it seems to coast a little better than the other so I might be ok for now... I have to get it to a track to do some real testing
Too bad tracks are getting so scarce around here (SoCal)
