Old 2019.08.03, 01:09 PM   #1
PN 93-102mm Multi Motor Mount
What damper is best fit for this motor mount at 102mm setup?
Old 2019.08.03, 11:14 PM   #2
The damper position does not change with the wheelbase. I believe it stays in the shortest position (94mm MM), don't have the mount to check.
Old 2019.08.04, 12:31 AM   #3
Which damper kit though? Does that mean any of the PN disc dampers will work?
Old 2019.08.04, 01:08 AM   #4
PN damper does 94/98 MM, it will work. Basically any PN ML type damper plate, or atomic 94mm if what I see in the low resolution pic on their site is correct.
Old 2019.08.08, 06:40 PM   #5
So if you are running a disc damper, do you still have to fly the tri-shock CF wing on that mount, or is there a simpler way to attach it?
I'm looking for a new MM pod, with my primary use likely to be 98mm, but I do like the possibility of 102LM. Trying to decide between this and the LCG v5 mount.
SuperFly is online now   Reply With Quote
Old 2019.08.08, 06:45 PM   #6
I was hoping to order the PN disk damper. It doesn't state it's 102mm capable specifically with mount I have. I do have the tri-damper cross bar that comes with the mount.
PN Racing Multi Offset Aero Dish Set starkweather Mini-Z AWD MA-010, MA-015 2 2012.09.09 03:08 PM
102mm wheelbase pros/cons ? redneckracer Beginner Questions 12 2010.10.21 06:41 AM
Kyosho multi offset wheel package: what offsets? RobinZ Parts and Hop-ups 1 2008.02.05 01:52 PM
Kyosho Volks Racing Multi Offset Wheel Sets arch2b Parts and Hop-ups 2 2007.10.13 05:00 PM
102mm wheelbase bodies gulfclk Parts and Hop-ups 0 2006.07.28 03:55 PM
