Old 2010.11.28, 03:32 AM   #1
mdowney
Pew-Pew!
mdowney's Avatar
Painting RCP tracks & rails
I'd like to paint the rails white and red and paint a logo or two across the tiles (for a special event). Any suggestions on the best way to do this? I don't want to mess up traction and I don't want the paint wearing off too easily.
Mike Downey | blog
Supporting Kyosho America | Peak Racing | KO Propo America | Fast Pace Racing
mdowney is offline   Reply With Quote
Old 2010.11.28, 06:44 AM   #2
bermbuster
GF Racing
bermbuster's Avatar
Any paint will mess up traction.....
your best bet is to paint the top of the rails......
GF Racing Team Driver
Old 2010.11.28, 07:33 AM   #3
kromie101
kromie101's Avatar
i know on our straight away tiles we have checkered flags that comes on it.i think they are a little thicker because of what ever they used. for the worlds philip had different tiles for the straight that had small little boxes for the starting grid.
my opinion i think use a stencil and good paint or do some research and find out what kind of paint/ink they might have used. i think if you do something only do it on the straights. if you want to do a bright color i would start with white and let dry real good.then do what ever bright color you choice. test on the back side of a tile,the side you don't race on. as for what berm said,i would only paint the tops of the rails. good luck,let us know how it works,eric
kromie101 is offline   Reply With Quote
Old 2010.11.28, 08:48 AM   #4
i've asked in the past and never received an answer as to what type of paint was used for the start/finish line. i have painted our club logo on a tile to see what it would take.
the tile SOAKS up paint. you need to find a thick paint type and preferably one that is textured to not cause slick spots. i don't recall what i used all those years ago but it worked out fine and looked good. it was very time intensive and took way more paint than i had guessed.
if we could get the same paint rcp used, it would be great.
Old 2010.11.28, 12:52 PM   #5
kromie101
kromie101's Avatar
you might be able to use bedliner spray in a can. i know wal-mart sells it and it has a coarse texture to it. might be a good base.let it dry well and then spray it with your color.
arch, now that you mention it.those tiles that have been painted by the factory are real coarse. i bet that bedliner spray might work well.
Old 2010.11.28, 12:57 PM   #6
i would be very careful with that stuff. the surface texture may greatly exceed the textured paint rcp factory uses. you do not want to create road bumps.
Old 2010.11.28, 02:27 PM   #7
hyper-me
hyper-me's Avatar
mabye use a dye from a craft store or mabye rit dye from walmart in the laundry section
hyper-me is offline   Reply With Quote
Old 2010.11.28, 03:01 PM   #8
mdowney
Pew-Pew!
mdowney's Avatar
Yeah I was thinking about dye for making the rails white and the corners bright red. I don't think it would be good for doing a logo down the straightaway. I'll wait and see if RCP says anything.
Mike Downey | blog
Old 2010.11.28, 03:08 PM   #9
winner
Send a message via AIM to winner
i would be very careful, most spray paint will melt foam, i'd test in the bottom of a tile before you go for it
winner is offline   Reply With Quote
Old 2010.11.28, 03:17 PM   #10
bermbuster
GF Racing
bermbuster's Avatar
The thing about the bottom of a tile is it has a different surface. It may not react like the open/rough side we race with.
Im thinking you will want some type of silk screen paint that you heat cure for a durable finish.
Old 2010.11.28, 10:59 PM   #11
cosmicsoul
The Mad Mexican
I would use an exterior flat acrylic latex paint. Sherwin Williams Super Paint, Duron Weathershield, MAB Seashore, Olympic, Behr, Gliden any of your major paint manufactures make one.
This stuff will stick to anything and should not melt the foam because it is latex. The acrylic resins in the paint will enable it to flex with the foam so it should not crack with any movement of the track.
The flat finish should give it some what of rough texture that won't be slick.
Jay Vasquez
MWG Racing
Old 2010.11.30, 10:13 AM   #12
briankstan
briankstan's Avatar
I've done this. it doesn't really seem to affect traction much.
I did the logo on the main race surface as well as on some of the rails. I used an enamel spray paint. it doesn't create a slick surface, it turned out like the starting strip texture that comes on the RCP track Surface.
the most important tip that I can give is to put on a lot of light layers, and let them dry in between coats. the paint drys quickly on the foam surface.
this has been on my track for 5 years now.
Old 2010.12.21, 07:53 AM   #13
SaiTam
Are you Fetted?
SaiTam's Avatar
That's cool and now I can put "chicane of death" and "SaiTam's corner", etc.... on the surface.
RCP Tracks Mini-96 IN STOCK + new 30cm sections RCPMini-z Tracks and GTGs 2 2010.11.06 11:03 AM
"New" RCP Tracks Website now *LIVE* Need Your Help *Free Track Giveaway* RCPMini-z Tracks and GTGs 19 2009.09.16 10:34 AM
RCP Tracks New Mini-z, dNaNo and HPI 1/32 scale track RCPMini-z Race Tracks, Track Layouts, Track Accessories 19 2009.06.01 12:50 AM
RCP Bank Turns & NEW SUPER MINI TRACKS RCPMini-z Tracks and GTGs 38 2006.06.28 05:24 AM
RCP MOR and MRC tracks RCPMini-z Off-Topic 14 2006.01.31 02:36 PM
