Old 2019.10.29, 09:05 AM   #1
LJH
MR03RWD Turns more one way than the other
Hello All,
I just received my 4th MR03RWD and set it up as a 94mm stock car. Right off the bat the car felt like it was turning more to the right then the left on the same amount of steering lock. At first I thought it was the differential action so yesterday I swapped in a known ball diff in good shape and it did not help. I tried resetting the KT531 Tx. and that did not help either.
Any thoughts on a solution? My muscle memory actually deals with the difference fairly quickly but the first few laps are interesting to say the least.
Cheers,
Jim
LJH is offline   Reply With Quote
Old 2019.10.29, 05:40 PM   #2
Whenever I have that problem, it's almost always related to the rear end in some way. Cracked or loose T-plate, diff collar on driver's side loose, motor wires binding.
Also check for an over-tightened front wheel, or bad bearings, but you said it was a new car.
Old 2019.10.31, 11:41 AM   #3
LJH
I addressed everything you mentioned and it was slightly better. I then took the steering servo assembly out, turned the pot, put it back together and all seems good now. Not sure what it was but glad to have it turning evenly.
I forgot how much fun 94mm cars are.
Thanks Super Fly.
Cheers,
Jim
My car is hopping and spinning out in turns bevo Mini-Z Racer MR-03, MR-03 VE, Sports Series, EVO 7 2011.06.05 08:23 PM
Car is loose on left hand turns only. double_green Setups 9 2010.10.07 01:15 PM
RCP Bank Turns & NEW SUPER MINI TRACKS RCPMini-z Tracks and GTGs 38 2006.06.28 06:24 AM
RCP - New 45 Degree Tiles, Large Radius Turns and Bumps Ken Mifune RCP Support Forum 82 2006.06.01 11:38 AM
Turns left faster than right bbeattie Mini-Z Racer MR-02 15 2005.06.22 01:33 PM
