Old 2012.03.29, 08:04 PM   #1
blaze0303
Guest
Posts: n/a
Blaze0303: My mini-z and 1/10th goodness!
Yokomo D-Max my pride and joy 1/10th
MR-015 (retired)
MR-02EX (old config)
Some random photos of my equipment
Old 2012.04.03, 07:23 AM   #2
blaze0303
Guest
Posts: n/a
Even MOAR!
Current setups - The pink one is the MR-02EX with alot of R246 hop-ups. Running 102mm alum motor mount, R246 BBS motor, Kyosho ball diff, Kyosho front springs (hard), Kyosho knuckles, R246 ball bearings, R246 roll and oil shock, Kyosho carbon t-plate (hard) and a 9T pinion.
My old MR-015 was swapped into the black MR-02 chassis and has the following hop-ups. Kyosho medium front springs, Kyosho carbon t-plate (medium), Kyosho oil shock and a 9T pinion.
Both cars are using narrow Kyosho 40's in front and wide Kyosho 20's in the rear.
Old 2012.04.03, 06:51 PM   #3
blaze0303
Guest
Posts: n/a
I'm looking for feedback espcially on the pink 02 from some of the experienced guys on this forum. I run on hard carpet, so any tips on making my setup faster would be highly appciated.
Old 2012.04.03, 11:25 PM   #4
imxlr8ed
imxlr8ed's Avatar
First off, I'd trim those motor wires back a bit, looks like they may cause some unwanted rubbing. Might want to lose the big yellow resistors too, pointless IMO.
Your cars look great though!
http://www.howfastareyou.com
SUPPORT LBR!!!
(Local Basement Racing)
imxlr8ed is offline   Reply With Quote
Old 2012.04.04, 12:49 AM   #5
blaze0303
Guest
Posts: n/a
Thanks a lot, I was actually thinking about ditching the resistors, and you just solidified that for me, they shall be gone tonight. If my soldering skills feel up to par i'll also shorten the wires. Thanks for the advice.
EDIT - I took your advice and it turned out great!
FS: RTR Kyosho 1/10th rally car, Airtronics MXA ChattavegasSE Mini-Z Marketplace 9 2008.05.29 10:33 PM
Chicago Mini Z/Micro Races HauntedMyst Tracks and GTGs 2 2004.01.22 08:24 PM
Noble Pieze Prize For Mini Z Breakthroughs NOMOTORLIMIT Miscellaneous Discussion 0 2002.12.07 12:55 PM
My rookie review with my first mini F1 West.F1 Mini-Z F1 MF-010, MF-015 5 2002.06.17 10:28 PM
Installing 1/10th Scale Electronics in the Mini Z Racer CTRallyRacer Parts and Hop-ups 2 2002.03.04 07:55 AM
