Old 2018.03.15, 09:37 PM   #1
Zeromerk89
RA29 PCB into an MR02?
I'm trying to fix up an old MR02 for a friend of mine. Gave him the FHS radio andPCB out of my MR03s. Ive wired up the servo motor from the old 27mghz PCB onto the RA29. Once I turn the car on the servo motor just runs?
Any help would be appreciated.
Zeromerk89 is offline   Reply With Quote
Old 2018.03.15, 11:45 PM   #2
switch the wire polarity
my custom body album...
Old 2018.03.16, 02:15 AM   #3
Servo motor wire that is...
Old 2018.03.16, 06:41 AM   #4
Zeromerk89
Lol,. I did. It still constantly runs. If I slip the servo motor into the servo gear case, it will go one way and stop. Is there a possibility the RA29 needs the coreless motor?
Old 2018.03.16, 07:15 AM   #5
How many wires do you have going to the pot? Post a pic of the servo assembly if you can. It should work in the mr02, as long as you have 3 pot wires and 2 motor wires.
If it goes one way then stops while in the servo assembly, then that's usually reverse polarity on the motor. Switch them again, then assemble servo outside of the car and test again.
If the pot is not centered, the motor should spin one way. If pot moves to the opposite side, the motor should spin the other direction. When assembled, this should recenter the steering. If the steering locks to one side or the other, then the polarity on the motor is reversed, since its turning the gears the wrong way to try to center them.
Old 2018.03.16, 08:51 AM   #6
Zeromerk89
Thanks EMU. I'll post pics later. I've never messed with a PCB aside from re-soldering the motor leads for a MA020VE.
FS: MR02 (With MR01 PCB) Draconious Mini-Z Marketplace 17 2009.09.05 06:13 PM
mr02 pcb board dohc Mini-Z Marketplace 6 2007.10.23 08:39 PM
MR02 PCB into a F1 revzalot Mini-Z F1 MF-010, MF-015 15 2006.10.31 05:25 PM
Wtb Mr02 Pcb SuperFly Miscellaneous Discussion 2 2006.05.30 08:44 PM
MR-01 PCB on a replacement MR02 chassis Cian@work Parts and Hop-ups 26 2003.10.04 07:40 AM
