Old 2003.06.23, 10:33 AM   #1
hrehowsik
Deep Sea Gangster
hrehowsik's Avatar
mini z tool kit
hey all,
just bought a mclaren f1, my first mini z, and some hop-up parts (ball diff, bearings, etc.) i'm obviously going to have to purchase a set of small screw drivers but i was wondering if you guys could recommend anything else i should pick up while i'm at the hardware store.
thanks
hrehowsik is offline   Reply With Quote
Old 2003.06.23, 10:36 AM   #2
Zmiester
Mini-Z Novice
Funny you should mention that, as I am going today to buy new screwdrivers as my current small set does not work on these screws. You may also want to purchase a nut driver that you can use on your whees.
Zmiester is offline   Reply With Quote
Old 2003.06.23, 10:51 AM   #3
Ken Mifune
2-Z or not 2-Z...
Ken Mifune's Avatar
re: small screwdrivers
Don't the Mini-Z size fool you. You'll be better off buying a full-size screwdriver so you don't strip the screw heads. Bring the Z with you to the store.
-Kenichi's Album-
Old 2003.06.23, 11:32 AM   #4
RCPMini-z
rcptracks.com
This has been my experience also. Most of the screws on the chasis are screwed into plastic instead of a nut. This can require alot of torque to get the screw tight, especially on the antenna. I have Mini-Z hex drivers for the wheels and I use scredrivers with a big handle and small phillips head for some of the screws. The smaller Mini-Z screwdrivers just don't have enough grip and head for some of the screws. It is not a bad idea to have one set of each.
Old 2003.06.23, 12:12 PM   #5
i have a #0 2 1/2" fat handle philips that works well. i replaced my previous skinny handle one. don't forget to get an allen wrench for the set screws on ball diff collars, some motor clips and various other parts. i wish they made hex head screws or some other format that is less prone to stripping.
Old 2003.06.23, 12:57 PM   #6
hrehowsik
Deep Sea Gangster
hrehowsik's Avatar
thanks for the advice. yes, i used to race 1/12 scale on the carpet years ago and the size of my z has me fooled a little i think. i like the idea of using full size tools instead of eyeglass screwdrivers or something like that. ok great, so i'll guess you guys will hear from me again once i break something.
thanks
FS: RCP Mini 96 and Expansion Kit Anizzle Mini-Z Marketplace 11 2007.10.12 02:46 PM
Mini 96 + Expansion Kit For sale Zrc Miscellaneous Discussion 11 2005.09.05 08:45 AM
XMod light kit modified for Mini Z? CoconutSport Mini-Z Science 12 2004.01.15 02:07 PM
