- Holding power 3 stage (gain) of servo, speed, punch and the dead band (blind sector setting of 5 stages), be able to set damping (stop operating characteristic 2 stage) and limit with the reception field, as for the amplifier drive frequency 3 gradual adjustment possibility.
(throttle/Brake has multiple settings of strength? can change out put strength of radio?)
- Special such that the gold plated part which resistance it can serve to the electric battery contact point low is adopted the private AD band +ICS loading ・冷#㏍・ in the MR-02MM chassis.
(Conductors are gold plated, like that smoke gray chassis set)
- Adopting digital steering wheel servo it improves resolution and holding power.
(you can change the throttle and steering settings lol)
- Preparing 20 bands in the 25MHz band with the AD band.
- Texture small-scale stability operation just of FM radio wave.
(its FM not AM...) lol
- Connecting the transmitter and the receiver to the respective computer directly, equipping the ICS function which can do various settings.
(you plug the TX into your computer to change its settings...)
- That way in the ARC system correspondence.
(This means it has the lap counter ability in the electronics... I think..?)
- The special specification which with the upper cover of yellow is understood at the glance.
(This measn the chassis is yellow instead of blue...)
my point was i used the edit button and added comments to each line above... even saw it after a few minutes guess he reverted to a saved version of forum or something... that was between that post and when i edited it...
Well I am glad the different cars are coming out no matter what the make I will need several to add to my collection. It is time the we find more than MB and Vetts as the only shells raced I like a mixed field. the F1 and the 350 look like good shells and some of the others might be made to run well enough to rid of us of the track full of the same.
