Old 2020.02.16, 02:22 PM   #1
NoBrainer
NoBrainer's Avatar
ZRound v1.19 build 1 issues I can't solve
2 issues.
1) I can't change colors on secondary monitor background.
Tried:
[MONITOR]
EfectoPaso=Claro
ColorLetraMonitor=$00000000
ColorLetraMonitor2=$00000000
ColorSombraLetraMonitor=$00999999
ColorCabeceraMonitor=$00202080
ColorLetraCabeceraMonitor=$00000000
ColorFondoMonitor=$00000000
ColorCocheParadoMonitor=$00202080
Still get the original colors
2) I bet this is a win10 issue, but my "speaker" announces the lap times without ",", so I get something like 5409s... instead of 5,409s
I have tried both "speakers" on my system.
I have english text and keyboard, but I have also installed norwegian keyboard. I can't figure out what I need to change.
Old 2020.02.16, 02:28 PM   #2
I've had nothing but bad luck with speech. sometimes it's english, sometimes spanish. sometimes if pronounces names, other times just reads letters.
Old 2020.02.16, 02:32 PM   #3
NoBrainer
NoBrainer's Avatar
lol
it works great except for that missing ","
Old 2020.02.17, 02:40 PM   #4
zround
Let me make some tests on an English Win10 installation (speaker, regional settings, ...).
I will post a check-list about the right settings.
Old 2020.02.18, 05:20 AM   #5
NoBrainer
NoBrainer's Avatar
Thanks man
Do you have any hints on the color on the secondary monitor as well?
Old 2020.02.18, 06:52 AM   #6
Thanks. I’ve had the speech issues in multiple computers. Most recent is brand new Lenovo workstation with English set as language and however i install zround, it’s never fully correct. Absolutely not ruling out user error as well I make mistakes like everyone else.
Old 2020.02.22, 06:46 AM   #7
NoBrainer
NoBrainer's Avatar
Hey Jesus have you had the time to look into my 2 issues yet?
Do you need anything more from me before you can do some testing?
Old 2020.02.22, 01:35 PM   #8
zround
I've been playing with TTS and Colors and this is what I've found:
Text To Speech
- When English language is choosen at setup time, there are some settings that are not loaded properly. It is not your fault, it's me. . ... It's because there is a default text on the installer and it should be "empty". I don't change tts custom settings at install time if they are already defined to prevent override custom setting with software updates. Next release will include the setup fix.
These are the affected texts:
You can "restore" defaults to English using the "Default" button.
I've found another bug . The "voice" selection doesn't work. You must restart the application to work with a new one. I've solved for next release.
Please, let me know if it works.
Monitor
First, make sure you edit zround.ini before starting zround. Youa can see the exact location of the configuration file at startup.
I've tested your settings and they show as expected (and I don't like them ). I've just edited zround.ini and copy/paste the values to my [MONITOR] section.
Here your values and explanation:
If you add the entry:
FicheroFondoMonitor=
Then the background color will be black (ColorFondoMonitor). As you have defined a black text color for even and odd lines (ColorLetraMonitor and ColorLetraMonitor2) you won't see nothing. You should change this.
And here the documentation and examples link: https://www.zround.com/wiki/doku.php...colorsmonitor2
It may be I include them on settings as well to avoid editing the file ... some day
Please verify you don't have two [MONITOR] entries on zround.ini file. The order where you put the key/values doesn't matter, all of them are take into account if they are between the first [MONITOR] line and the next section name.
Decimal point
I've tested on English and Spanish regional settings and it worked. @NoBrainer, could you please tell me the regional setting do you use and your selected voice?
Best regards,
Jesús.
Old 2020.02.24, 01:29 PM   #9
NoBrainer
NoBrainer's Avatar
Reverted back to default for Speach, I will test this week.
About the [MONITOR], I now see that I have edited my personal .ini file and not zround.ini. So with your tips about the "original" ini.file, it works like charm.
Now I can do the testing on what I actually like to have on my secondary monitor. Thank Jesus!!
I will get back to about regional setting after I have testet with "default" first.
Much appreciated
Old 2020.02.24, 04:20 PM   #10
NoBrainer
NoBrainer's Avatar
I might just have "figured" out text-to-speech
I got Norwegian keyboard and therfore I use "," and not "." as my delimiter.
With english keyboard it's "." standard instead of "," and then it seems to work.
I got to test a bit more, but this is my hint of what is wrong.
That is just like I thought, not ZRound but my setup being wrong...
Old 2020.02.24, 05:36 PM   #11
zround
:-). Thank you for your feedback.
ZRound v1.18 Build 1 and Robitronic USB NoBrainer ZRound 9 2019.06.25 04:02 PM
ZRound Suite 1.15 build 6 NoBrainer ZRound 12 2016.10.30 09:37 AM
ZRound 1.12 build 24 NoBrainer ZRound 6 2014.12.29 03:36 PM
ZRound Suite update 1.10.10 zround ZRound 1 2011.09.14 02:06 AM
ZRound Suite 1.9 zround ZRound 10 2010.02.19 12:25 PM
