Go Back   Mini-ZRacer.com Forums > 1/28 Scale Chassis Discussion > Kyosho > AM Frequency
Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Old 2010.07.13, 02:12 AM   #16
syafiq
moe-otaku
syafiq's Avatar
Originally Posted by eztuner12 View Post
No pics, sorry.
I use an Exacto blade tip, try to introduce the Exacto tip between the POT black case and the clear plastic cover and pop it out.
Hope this helps.
Cheers
then how did you put it back?
syafiq is offline   Reply With Quote
Old 2010.07.13, 02:53 AM   #17
eztuner12
Do you want to go fasst??
Just press the clear cover back into place.
Be sure the POT is centered & aligned with the steering gears as with the steering system, at the time you place the POT back into its place in the chassis area.
Cheers
Old 2010.07.13, 04:20 AM   #18
syafiq
moe-otaku
syafiq's Avatar
Cheers
do i need to glue the clear cover?
Old 2010.07.13, 05:48 AM   #19
no need to glue it... just press it back into place as eztuner mentioned...
Old 2010.07.13, 11:51 AM   #20
eztuner12
“NO” Don’t glue it, as herman said!!!!
In fact I enlarged de center hole of the clear plastic cover just a bit in line to avoid any binding between the plastic cover and the center pin of the Pot, which I noticed makes some resistant due to some binding between the clear plastic cover and the steering gears case were the pot is placed.
Cheers
Old 2010.07.14, 08:20 AM   #21
syafiq
moe-otaku
syafiq's Avatar
Cheers
do you have any tip to make sure i dont crack the plastic cover. because it seem that the potentiometer was never meant to be open.
Old 2010.07.14, 09:22 AM   #22
cowboysir
its a somewhat flexible plastic and the pot is originally assembled so the cover could come off...its a procedure thats done for other scales of servos as well so just be careful yet desicive in using the hobby knife to pry open the pot cover.
The best description i can give you (without pictures of course)is:
1. Hold pot in fingertips of left hand
2. hobby knife in other hand
3. slide blade carefully under cover on one side and pry a bit
4. Work blade around to other side while slowly prying with the knife all the while.
5. This method should slide the pot coer up the pot shaft.
6. Remove and perform maintenance.
my custom body album...
Old 2010.07.14, 11:13 AM   #23
eztuner12
If we are talking about a Kyosho Mini-z MA-010 the clear POT cover won’t crack. Just pull open with the tip of a Exacto blade one side, then go to the opposite side and pull too, repeat until you get it completely out. With a 800 or thinner water sand paper you can enlarge the clear plastic cover center hole, by rolling the sand paper to a size it would fit into the cover centre hole, file even just a bit so that the plastic cover fit into the POT center pin and still can be rotate smoothly when you place it back on the POT. Thru enlarging “just a bit” the plastic cover center hole it makes it easier to remove the cover next time you have to clean the pot, plus it will eliminate any bindings when the pot is in action (moving left to right) in its place against the steering gears case.
Hope this helps
Cheers
Old 2010.07.14, 11:17 AM   #24
eztuner12
Thumbs up
Great instructions to follow...
Note: When I refer to the POT pin, I am talking about the POT center shaft.
tips page...? herman Site Feedback 10 2002.06.04 01:02 PM
