Old 2009.10.08, 11:05 AM   #31
pedrocamp
Ain'tSoldEm
Only room on the scooter for two!
Old 2009.11.12, 11:32 AM   #32
Got a few things in from Kyosho that we have been wanting especially T-plate sets. Got some front F-1 springs and a couple of bumpers. Sorry. No 03's yet. Pn part selection is quite good right now. I think there are some of the super lite weight dif shafts as well as aluminum T plate holders.
See everybody there.
Old 2009.12.02, 03:16 PM   #33
OK boys and girls. The 03's are in. We also got a couple of Lark McLaren ASC's along with a good supply of 962KH white bodies and LM wheels for both the Mazda and the Porsche. We also got some Ferrari 430 white bodies along with one of the Megane Renualt's just for giggles.To compliment the 03 we got in some T-plates and optional front springs from PN. Aluminum dif shafts are back in stock along with the high clamp force T-plate holders. We have stocked a full set of the new PN option wheels and hubs that can be used on either the 2WD or AWD chassis. We picked up a selection of the new PN locking spur gears as well as F-1 bumpers plus K20 and 30 slicks and one each PN F-1 motor pod and a 94-98 LCG V2 pod.
See everybody tomorrow.
Old 2010.04.14, 07:42 AM   #34
The PN aluminum upper arms in both 0 and -1 degree settings as well as the low down knuckles for the 03 are in stock. There is a fairly good supply of DPS kits and parts from both Kyosho project246 and PN on hand as well. 64P 12T pinions are back in stock along with the super lite weight dif shafts from PN.
If you have a request for the stocking of an item then please see me at the track on Thursday so I can get it on the next order.
Old 2010.12.17, 08:46 PM   #35
The motor cans that everybody wanted along with a couple sets of thin Neo's some 19mm wheels and Don's balls are all in stock. The screws for james and the rest of the stuff that everybody needed as well. More goodies from Kyosho should be there before X-mas.
Old 2010.12.18, 07:56 AM   #36
pedrocamp
Ain'tSoldEm
Lookin for a PN lower arm kit, silver, in stock?
High Speed Hobbies
Old 2010.12.18, 09:10 AM   #37
I think so but will check and verify. MR3052WS correct?
Old 2011.03.15, 02:26 PM   #38
Will have bearings and wheel nuts in both nylon and aluminum back in stock for Thursday. Ordered 11T pinions and spur bearings as well as a full compliment of the new 128P pinions and spurs. Only got a limited quantity so if you are interested you know the drill. The specifically requested parts all showed in stock so they will also be available.
Old 2011.03.31, 08:51 AM   #39
Currently inventories are in good shape but there are a few items to be carted for the next order.
If there is anything specifically needed by next week please bring a list with you this evening so I can get it in the order. Part numbers would be appreciated.
Marwan. I spoke to KoA yesterday and had them add to the US stocking list the items that you found numbers for. Should be available here soon. Although there are some reported logistical issues so far no shortages or glow in the dark items have been reported.
Old 2011.03.31, 09:54 AM   #40
Daddy Rabbit
Mike,
What type (brand) motor spray do you guys use at HSH?
Andy
LET'sGo Racing
Daddy Rabbit is offline   Reply With Quote
Old 2011.03.31, 10:08 AM   #41
The Reedy stuff. Performance 3 I think it is. The Cup race site carries it as well.
Old 2011.05.17, 01:29 PM   #42
Adios AMBigo
The old timing system shipped out and the new I-Lap system is on the way. With luck it should be on hand for Thursday along with the new transponders. Hopefully Jay got word through Marwan to bring his just in case. I will have the new bridge ready.
See everybody on Thursday.
Old 2012.03.20, 10:23 AM   #43
Our inventory is near an all time high but there are a few things that are needed to maintain the "Box Stock" class. Mostly items foumd in the various small parts packages that "K" puts out. T-plates come to mind. It appears that to get an MR-02 plate you have to get one of the various pod kits. For the 03 you get it in with the tie rods and knuckles. If there is anything specific that anyone needs then please write it down for the shop or write it down for me for Thursday.
If there is anything specific PN that is needed the same holds true. We will get an order ready for next week so let somebody know.
The regional is closer than we think so make sure you have enough wheels and such as the rules don't have a lot of room for some parts other than PN. Especially motors and components.
Old 2012.03.29, 09:57 AM   #44
We have gotten everything in that was requested from PN is available for pick up this evening if you haven't gotten it already.
We got a decent supply of the necessary bits to keep box stock exactly that. The only thing that comes up on back order was the LM difs and K30 front tires.
The shop got a call from "K" saying that items were back in inventory so Jim said fill the back orders which means that everything should be available in time for the regional.
Old 2012.03.29, 10:10 AM   #45
kwsmith29
Thanks Mike..
kwsmith29 is offline   Reply With Quote
Transformers Red Alert arch2b Custom Bodies 20 2007.01.04 01:26 AM
NooB Alert! ExtraPickles Miscellaneous Discussion 2 2004.09.16 12:08 PM
Product Alert! buckaroobonsai Mini-Z Monster MM-01 2 2004.01.27 01:00 PM
ALERT track suface ["RUG-STOP"]10'x16' ???? acurarsxer Tracks and GTGs 7 2003.02.28 02:16 PM
