Old 2011.01.25, 10:29 AM   #16
pinwc4
pinwc4's Avatar
So is anyone good with math that could help me. I figured out an equation that translate the timing values to IDs, it was a ln based curve so it was pretty easy to calculate.
This works well when just 1 transponder is detected but if 2 or more are under the bridge at the same time all the timing values are mixed together. I can manually look at the data and see how it could be split apart in each case to get the individual timing values for the transponders but I do not know a good mathmatical method to split this data back apart. The timing data for the transponders is staggered so that you will not get any 2 transponders that would be a harmonic of each other so the timing values.
Is there anyone that could help me with this data?
Old 2011.02.26, 05:03 PM   #17
pinwc4
pinwc4's Avatar
OK, I think I got this figured out. I have been testing with multiple transponders under the bridge and it is separating the signals properly. I have a new release out now, version 0.56, and it includes this first attempt at Giro-Z support.
Ultimately I just went with a brute force method of calculating a bunch of variations of the signal instead of using any advanced signal analysis. But even on my old Pentium M laptop the CPU usage stays low even with a constant stream of data if the transponders are just sitting under the bridge.
Get the latest version at http://www.flipsideracing.org
WTB Lap Counting System pfm racing27 Mini-Z Marketplace 0 2008.08.07 09:38 AM
WTB; core lap counting system Davey G Mini-Z Marketplace 3 2008.03.10 02:24 PM
FS: core lap counting system with 21 transponders wcrotty Mini-Z Marketplace 10 2007.12.21 12:36 PM
orion lap counting system question... ruknd@aol.com Off-Topic 9 2005.02.03 11:06 PM
Does KO PROPO's Mini-Z lap counting system work with iwavers? XCmdr Mini RC 3 2004.05.07 07:36 PM
