Go Back   Mini-ZRacer.com Forums > Manufacturers > Kyosho
Old 2011.01.25, 09:03 PM   #1
Sinister_Y
Sinister_Y's Avatar
Problem installing pivots balls into alloy MR03 arms (Kyosho part #MZW415)
When assembling the arms, putting the pivot balls into the alloy arms, the balls kept falling out. I tried initially to just spin them in from bottom into top and they still didn't stick in. Then I ended up pressing them in from the bottom as I thought they needed to be pressed in. This seemed to work but one would not pivot anymore. After trying to pivot it,it would fall out. Then they just kept falling out making this setup useless. I was going to use this system with the Kyosho inner tube shock setup. Due to this issue, I ended up just using the inner tube shock plastic arms but would like to get the entire system working.
Any suggestions? Is this a manufacturing issue?
Also, which way should the balls sit finally? there are 2 different surfaces to the ball. One end (top) is smooth, whereas the other (top) is raised.
Mini-Car Club of Canada (MC3)
www minicarclubofcanada com
Old 2011.01.26, 08:12 PM   #2
Sinister_Y
Sinister_Y's Avatar
Note to anyone interested, I called and spoke to Customer Service today. They are analyzing the issue. I will provide an update once I hear back.
Old 2011.01.26, 09:35 PM   #3
lfisminiz
lfisminiz's Avatar
Good to know..let us know. When i tried them awhile back, same problem.
Old 2011.01.27, 09:04 PM   #4
iruninsoga
I'm not using these arms
Doesn't spring tension keep the balls inside the cup when fully assembled?
The smooth end should be in the cup and the end with the protrusion should be facing the lower arm.
iruninsoga is offline   Reply With Quote
FS: 3 built AM MR-02 chassis with entire accessory collection builthatch Mini-Z Marketplace 10 2010.03.08 08:08 PM
GPM .. they have many parts.. are they all available? bcuzau Mini-Z AWD MA-010, MA-015 5 2006.03.14 08:12 AM
I just bought an F1!!!!! RedRSX Mini-Z F1 MF-010, MF-015 11 2004.03.19 10:45 AM
