just got RX1177, i'm running 98mm, removed standard pod but left atomic t plate using thinking it would have been fine with RR mount but it isn't, wheelbase became shorter hamping shell fitment, another issue i see is unable to use current offset rims +3 on rear as wheel exceed arch with mount have go down to +2 if get it to line up as 98mm is that right?
help
using gtr F1 & lambo lp 670-4 yes my car mm, car is 98mm, +3 rear wheels with stock motor mount all is well, moving t plate then the wheelbase too long instead of wheels being fouled at arch by clip its fouled at rear of arch as well as tire scrubbing on upper of arch too,
theres no sweet spot in centre, is there an specfic t plate to use with mount for 98mm?
Just wanted to mention that I put the 945 mount through hell today (6 hour endurance race, plus a normal race night), and it gave me no problems whatsoever. Put up some very fast laptimes as well. It has to be the best 94mm mount that I have used to date...
Make sure you use a hobby knife to clean off any of the burs off. After that, try to press into the holder to just locate it in the hole and then just use either a hard, flat surface or a set of pliers to "press" it in.
We made them a bit tighter since the previous version some people reported a loose fit.
Cristian Tabush
REFLEX RACING USA
10 Time Mini-Z World Champions!!! http://www.reflexracing net
CT - I think it is great you taking the time to pay attention to details like the fitment of the delrin bearing carriers on your RR 945 motor pod. They are soo critical and I hate it when they are even a little loose. Good call making the bearing carriers a little more tight
__________________ *** TOP SECRET MOTORS *** [FONT="Book Antiqua"]
I used fine sandpaper to clean any burs in the plastic and gently sanded down the entire outer surface of the carrier while test fitting. Works great now.
I like that the bearing carriers are a little tight. As stated, a little knife/file work and they go in nice and snug. There is no play once they are installed, at all.
