Old 2002.09.14, 01:12 PM   #1
baseline
Guest
Posts: n/a
broke servo steering rod thing
I broke my servo steering rod stick thing that moves the steering tie rod thing.
is there a good way to rebuild it? would just crazy glue hold it in place and be strong enough to race and bang with?
i've already bought a second set but was wondering if i could salvage this one for later use.
has anybody tried drilling a hole and sticking a metal something in its place?
Old 2002.09.14, 01:34 PM   #2
Wedginator
I wouldn't use superglue. Most likely it will snap again. You could try an alloy tie rod which is more robust....
Old 2002.09.14, 01:43 PM   #3
baseline
Guest
Posts: n/a
hm.. I broke the tiny post that is built onto a gear in the servo gear set. are the metal alloy ones good? i heard they are heavier and may be slower?
Old 2002.09.14, 01:51 PM   #4
Wedginator
They are heavier, but not by much.... I use one and it works great.... not much difference in steering speed....
Steering Servo Motor G-Class Motor Tech 0 2004.12.29 09:00 AM
Servo broke while cleaning MoralThreat Mini-Z Overland MV-01 5 2003.11.13 10:55 PM
Steering Servo wiring help needed gregk Parts and Hop-ups 4 2002.09.06 11:02 AM
Any Diff with Stainless steel Steering pin thing? 91TalonTSI Parts and Hop-ups 6 2002.01.01 11:37 AM
