2002.09.05, 06:56 PM
Zen_gineer
206, by the Forum, for the Forum
I have several 206's in full WRC livery, ( the Twins grey and yellow). But up to this point, I've never had one that ran fairly well. The 206 shell is a bit top heavy and prone to loads of chassis roll due to the high motor mount.
Well things have changed quite a bit. The forum members have suggested and detailed many ways to make the 206 a decent runner. So, I dedicate this to those that contributed, you'll know who you are when you see the pics. Thanks!!!
2002.09.05, 06:57 PM
Zen_gineer
The originals are ok but here's the beginning of the racer.....
Note the antenna connector made from an old BEC connector and some thin wire. This was needed to connect the fixed rally style antennas.
2002.09.05, 07:01 PM
Zen_gineer
Note the reversed motor mount with extended o-plate, the mid mount suspension from a Squat 360 Lexan shell kit, and the Kyosho high mount monoshock.
2002.09.05, 07:02 PM
Zen_gineer
Semi-wide tires really help the traction, ball diff and a donated X-speed ala R.
2002.09.05, 07:05 PM
Zen_gineer
1 degree camber and toe in. Had to open the rear wheel wells towards the rear. This was necessary as the mid motor mount configuration make the motor clip come dangerously close to the chassis.
2002.09.05, 07:14 PM
Zen_gineer
Global contributions:
Phillipines, China, UK, Sweden, Finland
USA: West-MidWest-South
Open and Free Communication!
2002.09.06, 03:32 AM
Mini-Z Chief
Hi Damzer. I have the 206 shell too.
Can you summarize the list of tips and tricks you have used?
Haynes Manual: Prise away plastic locating pegs...
Reality: Snap off...
Haynes Manual: Lightly...
2002.09.06, 04:52 AM
Mini-Z Hog
Looks cool, i was looking to buy a 206 shell as well.
2002.09.06, 06:15 AM
Dam you DAMzer...
Making me envious of your amazingly nice 206's... and to top it off, a pair.
*shakes his fist with fury*
What wheels are those?
-Scott
2002.09.06, 06:27 PM
Zen_gineer
I swear I just responded to this from my e-mail notification, but its not here, so once again.....
The rims are semi-wide Kyosho
The yellow beastie is just for display. The red and yellow really contrast well together.
I am trying to source some more shells. If I do, I may offer some fully detailed bodies for sell or auction.
I have a tamiya 206 coming. Maybe a hi res scan of their decal set will result in a better 206 set. I'll reduce it and see if I can match it to the 206.
Go back through the posts and the pics, its all there.
BTW- do not post unless your avatar is BLUE
2002.09.06, 08:39 PM
Administrator
LOL, this is a seriosuly nice 206 race spec! It's a pretty good ad for the Mini-ZRacer.com Shop too!
2002.09.06, 10:03 PM
*drools some more*
-Scott
2002.09.16, 09:42 AM
Mini Z Driver!
Guys
I have faced it on the track and it is cool how DAMZer can drift it around the coners at times looks like an E-Brake turn slide then
back on the power for a quick coner exit.
2EZ
2002.09.21, 07:47 PM
Zen_gineer
Not used to a drift machine, but it kinda grows on you after a couple minutes. Much more controllable than the high mount motor configuration. Still, it will never handle like my NSX. Really need to take out the X-speed and use a stock to get the real nature of the set-up.
2002.09.26, 10:40 AM
Mini Z Driver!
Yes Yes !! do reduce power I think you should do that to all your cars. Your friend
2EZ
2EZ
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Tracks and GTG Forum Updates
arch2b |
Mini-ZRacer.com Announcements |
0 |
2007.06.22 12:29 PM |
